Congnos Control TM1 Webseet don't show anything, after .net4
Posted: Thu Jan 30, 2014 11:52 am
by Motyl
I have add xcelator excell sheet to architect (from architect i see this sheet)
After, i set sheet public.
Now i want select this sheet from tm1websheet properties:
Select websheet, but when selections open, there is nothing in dropdownlist.
Problem showed after instaling .net 4.0 on server
Sorry for my english :-(
Re: Congnos Control TM1 Webseet don't show anything, after .
Posted: Thu Jan 30, 2014 2:15 pm
by declanr
Sorry I might be missing the point here, are you trying to set it as the default homepage against client settings?
If so I think it used to be the case that only websheets in the .xls format were able to be selected and not those in the .xlsx format, I haven't got 10.1 installed at the moment to test this though.
Posted: Fri Jan 31, 2014 3:21 am
by Andy Key
Can confirm that it is still the case in 10.1. Homepage selected through the interface will not show you .xlsx. But this wouldn't have changed due to the .net version, so possibly isn't the issue!
Posted: Fri Jan 31, 2014 9:24 am
by declanr
Andy Key wrote:Can confirm that it is still the case in 10.1. Homepage selected through the interface will not show you .xlsx. But this wouldn't have changed due to the .net version, so possibly isn't the issue!
Yes, I would hazard a guess that its the .NET upgrade that may be the red herring and it's possibly a new sheet created since then, accidentally in the wrong format but you always think back to what you have changed recently AND if that's an upgrade of .NET you would be reasonable to take the assumption that .NET is at fault.
