Page 4 of 4
Re: Cryptic TM1 Messages Decoded
Posted: Tue Dec 04, 2012 10:37 am
by iansdigby
On running any TI process that, inter alia, populates a cube:
TM1speak (in message log) : "Cell type is real"
Human speak: "You specified that a data variable was of type Numeric but the cube cell you are sending it to is a string cell".
(or vice versa?)
Posted: Tue Dec 04, 2012 8:15 pm
by Alan Kirk
iansdigby wrote:On running any TI process that, inter alia, populates a cube:
(or vice versa?)
Real = Numeric. You'll sometimes come across an error like "cannot convert {whatever} to real" (can't recall the exact syntax of it); it means that whatever is trying to be input to a cell or otherwise manipulated cannot be converted to and/or is not numeric.
Edit: I expected that this would be referred to somewhere in the documentation, but the only place I can find it is in the API manual which is a place that most of those who don't wish to look programming death in the face and laugh at it will avoid. Page 10 of the 10.1 manual:
Value                  Description
TM1_REAL          A double precision IEEE floating point number.
TM1_STRING       A character string whose length does not exceed 64K bytes.
TM1_INDEX          A 32 bit unsigned integer.
TM1_BOOL          A logical value stored as 1 to indicate TRUE, 0 to indicate false.
TM1_OBJECT       A structure used to refer to objects managed by the API. Typically an object contains information about the server in which the object resides, and an index to locate the object within the server.
TM1_ERROR        A structure containing typically an error code and an error message string.
TM1_ARRAY        An array of values.
Items 1 and 2 are the only ones that apply to values stored in a cube, though.
Posted: Fri Aug 09, 2013 9:11 pm
by Wim Gielis
Another one:
Data spread failed.
You are a read-only user - as set in the }ClientProperties control cube - and you try to edit a numeric cell.
Posted: Thu Jul 24, 2014 9:48 am
by GWT
"failed to create empty document" when double-clicking on a SUBNM in Excel.
Try deleting the .tbd files in %appdata%\Applix\TM1
Posted: Fri Nov 29, 2019 8:00 am
by gtonkin
Process "xxx": Invalid parameter array size: Could not initialize process
You also get a failure on opening the error log and the log$ file remains.
The cause of this error is due to a drill process being created against cube A but the drill Assignment belongs to cube B i.e. the cubename in the parameters of your process is not the same as the one being drilled from.
Posted: Fri Nov 29, 2019 9:19 am
gtonkin wrote: ↑Fri Nov 29, 2019 8:00 am Process "xxx": Invalid parameter array size: Could not initialize process
Yes it's a right PITA that TM1 doesn't let you have truly generic drill processes. The closest you can come is to replicate a generic drill process per cube with count of N dimensions.
Posted: Wed Dec 11, 2019 1:56 pm
by iansdigby
A couple of favourites from older versions:
On cancelling a text output operation:
'Stop Now?'
On logging off an instance through the Explorer:
'Disconnect self?'
Posted: Sat Jan 18, 2020 2:43 pm
by gtonkin
A new one to me.
Using TM1ELLIST in Planning Analytics for Excel to show Members in a dimension.
When I refreshed the sheet I got the #SPILL! message as the element list would have over-written values further down in the column i.e. spilled over I guess.
This is an Excel error, not TM1/Planning Analytics for Excel - See Excel Help, Dynamic arrays and spilled array behavior
Formula overlap - Array formulas can't be input if there is anything blocking the output range. and if this happens, Excel will return a #SPILL! error indicating that there is a blockage.
Posted: Sun Jan 19, 2020 6:39 pm
by Wim Gielis
gtonkin wrote: ↑Sat Jan 18, 2020 2:43 pm A new one to me.
Microsoft has (finally !) launched a number of new functions in Excel to the general public. These functions are truly a game changer if you ask me!
Read here with Jon Acampora: https://www.excelcampus.com/functions/d ... ill-ranges
Or here: https://support.office.com/en-us/articl ... 88f5502fa2
Posted: Mon Jan 20, 2020 1:55 am
by EvgenyT
This is really cool, along side TM1ELLIST function. No more weirdly wrapped formulas lol
Posted: Mon Jan 20, 2020 11:14 am
by Wim Gielis
Indeed. A good number of really ugly and longwinded array formulas (confirmed with Ctrl-Shift-Enter) are hopefully gone now.
Posted: Thu May 13, 2021 1:55 pm
by Steve Rowe
TI data export error
......,Data Source line (1) Error: Data procedure line (57): Invalid real number "nullptr"
Error: Data procedure line (57): error repeats 1 times
triggered by using CellGetN versus a cell with a rule error #N/A being returned.
Fix your rule to make the error go away!
