I am simulating the D-day by switching the clock ahead to 2017 and this is what we will be seeing (?) in the admin host debug log. Admin server will fail to start.
Can anyone confirm this is the right steps to verify ?
5272 DEBUG 2017-09-29 00:58:55,708 TM1.Event mt_SetEvent: Set event 0x000000000000035C succeeded.
10512 DEBUG 2017-09-29 00:58:55,708 TM1.Event mt_WaitForMultipleObjects: Successful. Event 0 (0x000000000000035C) signalled.
3856 DEBUG 2017-09-29 00:58:55,708 TM1.Comm.SSL Message in file: ..\tm1_r7s\Sys_net.c Line: 4460 Msg: Error in acceptOpenSSL error code: 336151573 in .\ssl\s3_pkt.c line 1146.TM1 SSL error data SSL alert number 45
3856 DEBUG 2017-09-29 00:58:55,708 TM1.Server.Memory al_FreePool - apifunc# "0" - pool# "0" - poolsize "37158.000000"
If this is the case, I have a solution but this will only work with TM1 server and Perspective for now. Technically I can make it work with TM1Web, Cafe but this will require much more work.
I have tested it successfully with 10.x and 9.5. Not sure about 9.4 as I can't recall is 9.4 already running SSL mode.
This is what you will see in debug log for Admin host, take note of the timestamp:
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL SSL Connection accepted.
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Available ciphers:
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: DHE-RSA-AES256-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: DHE-DSS-AES256-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: AES256-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: EDH-RSA-DES-CBC3-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: EDH-DSS-DES-CBC3-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: DES-CBC3-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: DHE-RSA-AES128-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: DHE-DSS-AES128-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher Version: TLSv1/SSLv3, Name: AES128-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Comm.SSL Cipher used for connection: Version: TLSv1/SSLv3, Name: DHE-RSA-AES256-SHA
968 DEBUG 2017-09-29 01:06:05,007 TM1.Server.Network internal_net_Recv select on: 920
968 DEBUG 2017-09-29 01:06:05,007 TM1.Server.Network internal_net_Recv select returned: 1
