Error in IBM TM1 9.4 Web login
Version: PA 2.0.7
Re: Error in IBM TM1 9.4 Web login
Post by jim wood »
If I remeber rightly it can be found within the edit configuration page within the .net panel in the picture above. By defualt .net uses a user called something net. If you right click on my computer, select manage and then go to users you will see it there. (Apologies if this has changed in server 2003.)
