Page 2 of 2
Re: security overlay - what am I doing wrong
Posted: Thu Jun 26, 2025 11:26 am
by Wim Gielis
Further testing:
• a chore that runs a TI process can write without issue, when the chore runs on a schedule
• a chore that runs a TI process, when the chore is run by a particular user, will run with the security rights of that user
So you can you summarize:
- what do you see in your environment?
- is it equal to what I have documented?
- if needed, challenge IBM with the observations I/you made. When they say that all TIs run regardless of security overlays, that is not true. Remark: I tested in TM1 Architect and server 2.0.9.21 or so.
Wim
Posted: Tue Jul 01, 2025 8:56 am
by stingo
Wim Gielis wrote: ↑Thu Jun 26, 2025 11:26 am Further testing:
Wim
I have a process that writes a cell that is "overlayed".
we know the behaviour if we run manually that process.
Now if we put that process in a chore and schedule it, the process will run as an admin.
so the only benefit of the overlay is to prevent random users to run a process on a closed month.
I tested it just like that. I created a cellPut in a process
scheduled it for 5 mins later.
checked the result.
Posted: Tue Jul 01, 2025 9:14 am
by Wim Gielis
Correct. Chores should run from static cube values. They will not be stopped in case someone puts in a wrong value. That’s a responsibility for users. At least the manual runs are protected. If you want to have chores protected than take out the time to add validation code in the Prolog tabs.
