thanks yes i know where i can find the weightings
So now i got the update installation done to version 2.0.8.
orlando wrote: ↑Thu Sep 12, 2019 9:39 am Edit: if you mean i could set the weighting to 30 or 31 i think it will not work here, cause i try to build an avg over the montly value
noooooooo. don't do that. that will not help.....
i'm afraid that you didn't get the point for what the weighting is for. you should read the documentation for TM1 (i think you got the links in one of your other threads)
Done and works perfect!orlando wrote: ↑Thu Sep 12, 2019 9:39 am please do the following:
- update to PA 2.07 or better 2.08
- don't use UNDEFVALS in Rules
- don't use Zeroweightoptimization
- set the weightings for the elements you want to calc the avg for to 1
- check if you get trouble in other cubes this dimensions is used
- write the avg rule
- check the results
Thank you
now i can remove much of this help elements in the cubes here (ghost counter elements to get average)
Thanks my friend!
