Re: Automating TM1 in VBA
Posted: Thu Jul 02, 2020 12:31 pm
Hi Paul,
Thanks, I reopened Wim's thread as had the same issue. Where I'm stuck is getting n_connect to work with the automation run under the service account without being logged in. You said:
In the VBA i had set it to open TM1P.XLA as an initial step and it works but only when running manually, not when triggered from a TI process. Is there anything I'm missing here?
Oli
If you want to use Macros like N_Connect you will need to ensure that the TM1P.XLA is set to load in Excel when running under this account.
Oli
