TM1 9.1 SP4 OBDC Issue
vaneagle
OLAP Product: Cognos Express and TM1
Version: 9.4 to 10.2
Excel Version: Excel 02 to 10
Post by vaneagle »
Not sure if this is a bug or a feature! ;)
I need to connect to an access database to retrieve data.
I have created the ODBC under system DSN on the Windows 2003 64 bit server using odbcad32.exe. (32 bit here)
Now when i am back on my pc and in TM1, I 'create a new process', click on OBDC then browse for the connection i get an error,
'An error occurred while retrieving datasource names from the server'
Is it a compatibility issue between 32 and 64 bit?
Has anyone else had this issue?
Thanks in advance...
Re: TM1 9.1 SP4 OBDC Issue
vaneagle wrote:Hi All,
I'm guessing that you've looked through the FAQ post which leads you to this thread?
FAQ Thread wrote:64 Bit ODBC Driver Issues
Access ODBC connections
vaneagle
Post by vaneagle »
No I didn't actually as i did a search for OBDC drivers and variations on that within the forum.. I may need to step back a level in future.
Sweet.
Thanks for that..
I have tried one of these methods already. ie C:\WINDOWS\SysWOW64\odbcad32.exe which didn't work...
I shall keep reading...
