what is tm1rawstore?
jonathan.d
Version: TM1 9.4 MR1
Post by jonathan.d »
Couldn't get any information on the file tm1rawstore(with a timestamp) in the data folder.
Wondering what purpose does this file server, and when does it come into play when the model is running?
LoadzaGrunt
Version: LoadzaVersions
Excel Version: LoadzaVersions
Re: what is tm1rawstore?
Post by LoadzaGrunt »
What is in the file ?
harrytm1
Version: Latest version
Excel Version: 2003 to 2019
Post by harrytm1 »
i believe this is the temporary file that stores the audit trail of users. when the defined file size is reached, a permanent file is created. this file is locked as long as the server is running.
please correct me if i'm wrong here. thanks!
ashwinchitkara
Version: 9.5
Post by ashwinchitkara »
My understanding is that if the parameter within tm1s.cfg called AuditLogOn=T then TM1 Server writes into a temp file called tm1rawstore.<Timestamp>, created under the database directory. The entry in this log file are then moved to the final Audit log
Post by David Usherwood »
My understanding too.
It's a PITA because it sits in the data directory and interferes with taking server snapshots. Winzip skips open files but Windows Compressed Folders doesn't.
mattgoff
Version: 10.2.2.6
Excel Version: O365
Post by mattgoff »
David Usherwood wrote:My understanding too.
You can move it out of the model directory (I put it in my logging directory) with the RawStoreDirectory parameter in tm1s.cfg.
Matt
It is a documentation hole that I (and I'm sure I'm not the only one) have raised with IBM but you can configure the location of the rawstore in tm1s.cfg with the parameter RawStoreDirectory. I always just set it to the same path as the logging directory (why you would ever want to do anything else is quite beyond me).
(beaten to it by Matt)
:x :x :x !
There are few things that p1$$ me off more than finding out a crucial function is not documented. Takes me back to the bad old Applix days - 'Oh, didn't you know that? Everybody knows that!'
Grrrrr.
mattgoff
Version: 10.2.2.6
Excel Version: O365
Post by mattgoff »
David Usherwood wrote::x :x :x !
Grrrrr.
Well, I hate to defend Cognos, especially when it comes to documentation, but in this case it is in 9.5.1 Operations Guide under the tm1s.cfg parameters section. That's how I figured it out when I ran into the same problem after enabling the audit log and finding my automated backup zips were failing.
Matt
Oh....
:oops: :oops:
I was working on a CX 9.0 aka TM1 9.4.1 system when I found it. I'll have a look to see if it was in that help file. Let's hope it wasn't a senior moment....
AmbPin
Version: 9.5.2
Excel Version: 2007-10
Post by AmbPin »
Do you know if there is any guidance as to when it is safe to clean up files created in a raw store folder?
