is there something like a UNDEFVALS rules function in PALO. I need to distinguish 0 put in by a user from the default 0. Values are sent through Excel files, so as a workaround I would send a number little greater than 0 in order to be able to distinguish later.
If someone knows a better solution, let me know.
Thanks in advance,
Marcus
Marcus Scherer
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: UNDEFVALS rules function
Hi Marcus,
AFAIK it is not possible in PALO to make a distinction between empty and zero cells.
I can't think of a solution better than the workaround you're using right now.
Michel
Michel
