Rule On consolidation which matches the natural consolidation
MarenC
Excel Version: Excel 2016
Post by MarenC »
I have inherited a model which includes a rule that puzzles me and wondered if anyone may know of a use case for what I am seeing.
In a dimension there is a consolidation called "Parent" which comprises 3 children, "Element 1", "Element 2" and "Element 3", all with weight 1.
There is a cube which includes the above dimension, with the following rule:
['Parent'] = ['Element 1'] + ['Element 2'] + ['Element 3'];
Is there a situation where it is necessary to have a rule which matches the consolidation?
Maren
Re: Rule On consolidation which matches the natural consolidation
Interesting question.
I take a guess: a cube with rules at level 0 for these elements and without skipcheck and feeders ?
Or, child weights in the parent are not all 1 for some reason (different cube maybe) and here you need the sum where weights equal 1.
Wim Gielis wrote: Thu Feb 06, 2025 10:26 am Or, child weights in the parent are not all 1 for some reason (different cube maybe) and here you need the sum where weights equal 1.
But this you could resolve just with another rollup with different weights.
MarenC
Post by MarenC »
I don't think the weights are relevant as they are all 1, and lotsaram said, why would it be an issue?
Skipcheck and Feeder are included in the rule. There is an n level rule for the children, but they are complicated and there looks to be feeder statements in place for the children (but these are DB(If...) type feeders).
Maybe someone wasn't convinced by the feeders so put these rules in as a backstop? Does that even make sense?
Maren
lotsaram wrote: Thu Feb 06, 2025 11:30 am
Correct but then elements are named differently, element security might need to be set up, reporting / dashboarding could change. Maybe a quick and (very) dirty way to “solve” it. As weights are 1 anyway it cannot be the reason though. Just wanted to add it as a potential reason.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
I cannot see "N:" here. So I assume this rule is needed to override calculations on C: level
MarenC
Post by MarenC »
Hi Elessar,
That's a good thought, but if I comment out the rule, then the value just uses the consolidation and doesn't revert back to another rule.
I.e. trace cell just says consolidation and not any defined rule, and the value remains unchanged.
Maren
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
If I had to guess, 'Parent' used to be a leaf element and someone used that rule to make it the sum of the 3 other elements. Someone else came along later (or same person got a tiny bit wiser) and decided to make 'Parent' a real consolidation with the 3 as children and then forgot to remove the original rule.
