Ultimate Long TM1 quiz
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Ultimate Long TM1 quiz
Post by Elessar »
ardi wrote: Mon Sep 09, 2024 1:00 am Just curious: What you have called as Employee Dimension seems to be your Measures dimension in the cube?
Yes, it is :) Screenshot is from one of IBM samples, and I also do have many questions to them. Obviously this samples were made by trainees
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Next question will be on Thursday tomorrow, not on Friday. Stay tuned.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Oops, I've failed Thursday...
Correct answer:
Last column dimension's format is used.
Winner of this round is MarenC!
Question #37:
Source cube is without skipcheck, target cube is with skipcheck. Will feeder fire from cube without skipcheck?
Image 67.png (59.99 KiB) Viewed 84757 times
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Post by EP_explorer »
Yes - feeders will fire
MarenC
Excel Version: Excel 2016
Post by MarenC »
I am sure I have had issues with this in the past so I will say No. Hopefully you will tell us the exact cases where it will and won't, as that would be helpful!
Maren
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer:
Yes.
I know that they did not fire in 9.5.2. What version they begun firing on - I do not know, but in Planning Analytics they definitely fire.
Winner of this round is EP_explorer!
Question #38:
My data load process from csv file to TM1 cube is very slow. What can be the reason? What can I do with this?
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
Elessar wrote: Fri Sep 20, 2024 5:10 pmQuestion #38:
There’s many many answers to this. I’d like to share the points with others and post just one potential option:
I’m going to assume the server is V11. If logging is enabled, that adds overhead because each change is recorded. You should disable logging before the load with the CubeSetLogChanges function. Assuming this isn’t a read only cube, you should re-enable logging afterwards to preserve changes made to the cube by end-users.
Take care,
Adam
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Yes, may be several reasons of it
For example
1) there are a lot of complex rules and feeders in Cube and then you load data in it they are calculated (of course you can switch off Rules (CubeRuleDestroy), load data and switch on (RuleLoadfromFile) - it may be more faster
2) You are trying to input data in cells which are closed for changing (by rules for example) - and it will generate long error logs and slow process. You can check cells before updating by CellIsUpdatable command
3) May be the Target Cube is locked by another process and our proccess in Wait Status - wait the moment then the Target Cube will be unlocked to load data from csv
burnstripe
Version: 2.0.9
Post by burnstripe »
Related to feeders EP_explorer alluded to, I would also be reviewing model parameters.
In particular ForceReevaluationOfFeedersForFedCellsOnDataChange, performance modeler necessitated that this be set to T, but this setting will force more feeder evaluations to occur when loading data.
The main reason using the approach switching off Rules (CubeRuleDestroy), load data and switch on (RuleLoadfromFile) is to circumvent this behaviour.
Instead we can set the paramater to F (false). And if the feeder is data dependent (conditional) then we can retrigger/recalculate the feeders when necessary to do so, such as mapping or dimension updates.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Adam wrote: Fri Sep 20, 2024 8:51 pm I’d like to share the points with others and post just one potential option
Nooo, 1/3 points again!
There are other reasons. Anybody else wants to share this point?
burnstripe
Version: 2.0.9
Most likely cause for slow performance is long feeder times. As no ones biting here are some other avenues to explore are:
- other server activity /locking or insufficient threads. Are other threads running creating a lock or no available threads meaning it has to queue. (could also include someone leaving the ti debugger mode on)
- Anti-virus scanning, is the anti virus scanning too aggressive, throttling performance
- has the server exceeded physical ram, and now using paging.
- is the ti posting using cellputproportionalspread to a highly consolidated data point with no pre-existing data causing a huge increase in number of cells populated
- is the process using direct functions for mass creation of new elements. May be better using metadata or having seperate load for dimensional updates.
- cell being updated could be causing a stack overflow, generally recorded in the server message log if the case
- version of pa used has bugs or design changes causing slower than expected performance. I'm looking at versions 2.0.14, 2.0.15 which had significant problems. Particularly related to updating attributes
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer:
There can be many reasons. Most of them are already listed. I want to also add this one:
  • Export file is lame:
    • Heavy calculations are performed in data load process. You need to avoid this and export fully calculated values to this csv
    • File contains redundant data. CellIsUpdateable also takes time, and you should avoid it. File should contain only loadable data.
    • File is located in network folder and connection is slow
Winners of this round are Adam, EP_explorer, burnstripe! (Sorry Maren, this was too late, but yes, lame dimension order is also a good point)
Question #39:
You have requirement to disable consolidated input everywhere. How can you do this?
MarenC
Post by MarenC »
Not sure if this is allowed given we have moved onto Q39, but another one for Q38 might be dimension ordering.
Q39 - You are going to tell me there is a cfg parameter that does this? But I don't know it, therefore my answer would be to put element security everywhere to make all consolidations read. Be nice if there is an easier way...
Maren
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
I've added Q38's results here.
Regarding Q39: there are several options also. Anybody?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer:
there are several options:
  • First of all, doubt any requirement. You should ask, why should we disable consolidated input, and the answer will be 99% like "Users will enter value to super-total zero cell and explode the server". Therefore, ProportionSpreadToZeroCells=F in tm1s.cfg setting should fulfill this requirement well. @ascheevel, @MarenC, you have mentioned it before!
  • Set Consolidation TypeIn Spreading = Deny in Capability Assignments
  • Use "IF(ISLEAF=1, CONTINUE, 'READ') rule in }Celsecurity cube
  • Use ElementSecurity (it is more preferred than CellSecurity, because it is precalculated once with SecurityRefresh, while CellSecurity will recalculate each time user recalculates cube view)
I'm noticing that participants became less active. 2 months left, pull yourselves together guys!
Question #40:
Which activity causes stargate view removal?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Anybody?
As an example, I am optimizing rules and want to measure calculation time, but cached views are spoiling it. How can I purge this cache without server restart?
write
some
data
to
the
cube.
It doesn't matter where in the cube. It can be an unused portion which doesn't actually flow or consolidate anywhere. Just as long as some leaf level data is changed. The caching mechanism in TM1 is very non-granular and doesn't track calculation dependency. As soon as any data in a cube is changed then all cached calculations in that cube are destroyed. It doesn't matter if the calculations are unchanged becasue they don't actually have any dependency on the changed input data.
MarenC
Post by MarenC »
My understanding is that also updating a cube that the cube in question is dependent on will also destroy the cache.
I find that rather annoying as it makes caching almost irrelevant, up to a point!
Maren
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
Doesn't updating the VMM and VMT properties to values where they are unlikely to cache also remove stargate views?
regards,
Mark
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Correct answer:
Stragates are very delicate. There are several options again:
  • write-some-data-to-the-cube :) . Or even to any cube your cube depends on
  • Change cube's rule (Or other cube's rule your cube depends on)
  • Change alias of any element of any dimension in the cube
  • add+delete element to any dimension in the cube
  • DebugUtility( 125, 0, 0, '', '', '' );
  • Server restart ;)
Winners of this round are MarenC and Mark RMBC!
Question #41:
The cube and rule are shown on screenshots below. B1 is not fed. What will be in C1? Will it take numbers from not-fed calculated cells of B1?
Image 68.png (22.48 KiB) Viewed 81830 times
