Connect TM1 Perspectives(IntegratedSecurityMode 5) with CAMPassport in vba
kavitha2002
OLAP Product: tm1
Version: 10.3.10100.8
Excel Version: 14
Post by kavitha2002 »
Hello Everyone,
I have tried to connect to TM1 Perspectives in IntegratedSecurityMode 5 with CAMPassport in excel vba automatically.
Previously with 'N_CONNECT_CAM' with n_connect_cam_bridge.dll worked well in excel 32 bit. In the current latest vesion of TM1 Pespective will support only 64 bit. Same dll is not supported in 64 bit. So I set the CAMPassport in vba and connect to TM1 Perspectives as a workaround.
The problem is its connected to TM1 Perspectives but ribbon is not activated.
Kindly provide your input on this.
danieljarolim
Version: IBM Planning Analitics 2.0
Excel Version: Excel 365
Re: Connect TM1 Perspectives(IntegratedSecurityMode 5) with CAMPassport in vba
Post by danieljarolim »
Just hit the same issue yesterday migrating reports to 64 bit Excel. The n_connect_cam_bridge.dll provided by IBM is 32 bit only and so is the VBA template they provided at the below links. I just updated the code and reimplemented the GetCamPassport function in VBA that was in n_connect_cam_bridge.dll
https://www.ibm.com/support/pages/uid/swg21959177 / https://www.ibm.com/support/pages/tm1-a ... de-4-and-5
If anyone is still using Perspectives in 64 bit Excel and needs this you can download the file from IBM above and do the following to the module:
  • Search Replace "Declare Function" with "Declare PtrSafe Function"
  • Search Replace "Declare Sub" with "Declare PtrSafe Sub"
  • Search Replace "As Long" "As LongLong" It will make a couple of incorrect changes
  • Change back one instance of "As LongLongPtr" to "As LongPrt"
  • Change back "Dim lLenB As LongLong" to "Dim lLenB As Long" or the ReDim in that function will cause type mismatch errors
  • Change back "Dim cSize As LongLong" to "Dim cSize As Long" and
  • Update next line to cast the returned value to Long so it looks like "cSize = CLng(2 * TM1ValStringWMaxSize(hUser, vString))"
  • Comment out the 2 lines containing n_connect_cam_bridge.dll one is a definition and the other loads the library. This is a 32 bit dll and won't work.
  • Replace "If rcApi = 0 Or rcCon = 0 Then" with "If rcApi = 0 Then" since the rcCon assignment from the missing library load has been commented out
  • Add the new GetCamPassport function. Copy it out of the second file in this gist.
  • Replace "sPassportLong = Trim(Left(StrConv(sPassportLong, vbFromUnicode), 255))" with "sPassportLong = Trim(Left(sPassportLong, 255))" The new GetCamPassport functions returns the passport non-unicode encoded.
  • Update TEST_N_CONNECT_CAM() with correct connection details, load perspectives, and run the sub to test everything works.
Or you can grab the full updated module here: https://gist.github.com/danieljarolim/7 ... 656fa3443a
The updated GetCamPassport function:
Private Function GetCamPassport(ByVal camuri As String, ByVal servername As String, ByRef passport As String, ByVal Size As LongLong) As LongLong
    On Error GoTo ErrorHandler:
    Dim sResponseHeaders, sResponseText, sCamPassport, aData, sUrl, oMatch
    sUrl = StrConv(camuri, vbFromUnicode)
    With CreateObject("WinHttp.WinHttpRequest.5.1")
         .Open "GET", sUrl, False
         .setRequestHeader "Accept", "application/json"
         .setRequestHeader "Content-Type", "application/json; charset=utf-8"
         .SetAutoLogonPolicy (0) '(AutoLogonPolicy_Always) 'Connect using current user credentials
         .Send
         sResponseHeaders = .getAllResponseHeaders
         sResponseText = .responseText
    End With
    aData = Array()
    With CreateObject("VBScript.RegExp")
        .Global = True
        .MultiLine = True
        .Pattern = "^Set-Cookie: cam_passport=(\S*?);[\s\S]*?$"
        For Each oMatch In .Execute(sResponseHeaders)
            If oMatch.SubMatches.Count = 1 Then
                sCamPassport = oMatch.SubMatches(0)
            End If
        Next
    End With
    'passport = StrConv(sCamPassport, vbUnicode) ' This works here but results in the function returning a badly padded passport
    passport = sCamPassport
    GetCamPassport = 0
    Exit Function
ErrorHandler:
    GetCamPassport = 2
End Function
Very nice first post here 👍
Just a pity that the end of Perspectives was announced yesterday.
