Looks like it gives me incompatible dimensionality error. Could anyone help to confirm? Thanks.
e.g. Union( [dim].[a].children, [dim].[c].children )
Can MDX work across alt hierarchies from one dim?
Re: Can MDX work across alt hierarchies from one dim?
That’s indeed incompatible. Are you not trying to make an MDX view using those 2 sets of elements (the ones that are shared) ?
This can't work by definition. The hierarchies are separate entities. No C elements are shared.
You could use Generate to loop a set on one hierarchy and return the set of leaves (or even the set of C elements sharing the same name) existing in the other hierarchy.
- macsir
- Version: PAL 2.0.9
No, just want to see if it is possible in a MDX set.Wim Gielis wrote: ↑Tue Apr 23, 2024 6:44 am That’s indeed incompatible. Are you not trying to make an MDX view using those 2 sets of elements (the ones that are shared) ?
- macsir
Haven't used Generate function a lot but good to know.lotsaram wrote: ↑Tue Apr 23, 2024 7:16 amThis can't work by definition. The hierarchies are separate entities. No C elements are shared.
Then the answer is no, as what Lotsa also replied.macsir wrote: ↑Tue Apr 23, 2024 10:31 amNo, just want to see if it is possible in a MDX set.Wim Gielis wrote: ↑Tue Apr 23, 2024 6:44 am That’s indeed incompatible. Are you not trying to make an MDX view using those 2 sets of elements (the ones that are shared) ?
- Version: from TM1 9.4 to PA 2.0.9.6
Not possible, different hierarchies of a dimension are treated the same as 2 separate dimensions.
Ardian Alikaj
- PavoGa
- Excel Version: 2013 PAW
What is it you are trying to accomplish exactly?
Also, the example could be confusing. From the coversation, it is assumed that a and c are separate hierarchies within the same dimension and if so, why is children used? Or are a and c consolidations within the same dimension?
Is it:
UNION( [dim1].[consolidation_a].children, [dim2].[consolidation_c].children) (not possible)
or
UNION( [dim1].[alt_hier_a].[some consol].children, [dim1].[alt_hier_c].[some aconsol].children) (pretty sure not possible either)
or
UNION( [dim1].[consolidation_a].children, [dim1].[consolidation_c].children) (yes possible)
If separate dimensions or hierarchies, you could (maybe) generate an INTERSECTION of the two sets, but not a UNION as mentioned.
NOTE; an intersection could not be created using the INTERSECTION function, but GENERATE and StrToMember nonsense and it would be tricky if possible.
Ty
Cleveland, TN
Cleveland, TN
