}ClientGroups cube not in sync. with Cognos
monkey97
OLAP Product: tm1
Version: 10.1.10000.26473
Excel Version: 365
Post by monkey97 »
Hi all!
If we delete clients from security group on cognos, then the }ClientGroups cube is only updated when they log into Application Web or Architect.
We have to update it without clients login. We have to know, if there is anyone who is not in any group.
Is there any solution for this? Scheduled process or any settings?
Thanks in advance
Re: }ClientGroups cube not in sync. with Cognos
Yes, a simple TI process with the necessary loops. There are no builtin functions to give that information.
monkey97
OLAP Product: tm1
Excel Version: 365
Post by monkey97 »
But how can i sync }ClientGroups with Cognos BI?
Pls let me any help for TI process code.
I haven’t done that, if at all possible.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
You need to to search client*group relationships in Cognos Content Store database.
Here is the tables list: https://cogknowhow.com/t/cognos-content ... iption/906
Here is an example of SQL query: https://www.ykud.com/blog/cognos/cognos ... ew-in-sql/
monkey97
OLAP Product: tm1
Excel Version: 365
Post by monkey97 »
Hi!
Thanky you Ellesar!!! These are useful links.
I have got only one problem with it. We haven't got "groups_unwrapped" table in our database... and similar neither.
What is your opinion? Is it possible?
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
Is the Client Groups membership defined in Cognos or in LDAP (Active Directory)? If it is in Active Directory, you can run some powershell script to extract the User/Group mappings. If they are defined in Cognos, then you can run a SQL against Cognos Content Store database tables ( as suggested by Elessar)
Ardian Alikaj
monkey97
OLAP Product: tm1
Excel Version: 365
Post by monkey97 »
They are defined in Cognos, but we haven't got "groups_unwrapped" table in our database... and similar neither.
monkey97 wrote: Tue Aug 29, 2023 9:44 am They are defined in Cognos, but we haven't got "groups_unwrapped" table in our database... and similar neither.
Isn't it something that Yuri scripted in the SQL ?
monkey97
OLAP Product: tm1
Excel Version: 365
Post by monkey97 »
I tried this https://www.ykud.com/blog/cognos/cognos ... ew-in-sql/ ms sql script. Only the mentioned table missing.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Are you sure you've copied the whole script? :)
As Wim said, it's declared in the beginning using WITH clause:
with groups_unwrapped (parent_group_id, child_group_id, lvl)
as .....
vovanenok
Version: 2.0.9
Post by vovanenok »
You can use the Cognos REST API to check the group members:
https://developer.ibm.com/apis/catalog/ ... up_members
Then you can implement relevant logic to perform tasks such as removing users in TM1.
TeamOne Google Sheets add-on for IBM Planning Analytics
Let's connect on LinkedIn
