TM1 print report wizard
thomas_E
OLAP Product: TM1 Perspective
Version: 10.3.10700.60404
Post by thomas_E »
Hi everyone (wave)
I have a question regarding the print report wizard in TM1. I have several reports that users would like to print as a PDF. I discovered the print report wizard, but it somehow does not work the way I believe it should.
I want to print a specific sheet (which works) for a specific title dimension (which also works) as a PDF. If I select 'print single workbook' it works fine, but I want to have a seperate PDF for every element in my title dimension. The way to do that should be to select 'print multiple workbooks' and check the box 'Create a new workbook for each title', but when I then try to generate the PDFs I always get an error stating: 'was not installed correctly.'
Unfortunately, I can't do much with this error message, as the PDF print itself works, so I don't know what is missing (not installed).
Any help is appreciated, thanks!
Thomas
orlando
Version: PAL 2.0.8
Re: TM1 print report wizard
Post by orlando »
Hello Thomas,
You mean the one from the old Perspektives? I think it stopped working a few versions ago. I just tried it again - but it no longer works for me.
Many greetings
orlando
thomas_E
Post by thomas_E »
Hi Orlando
Yes exactly, we use the old Perspective version of TM1. Well that's a bummer, but at least I know it's not a problem on my end.
Thank you!
Regards Thomas
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
I can't find a working download link, but Quebit had a free tool called "Print Reports" that mimicked the old functionality. They also have their ReportWorq tool with a whole host of other features available by subscription.
*I am not affiliated with Quebit
WilliamSmith
OLAP Product: TM1 / PA / PAx / PAW
Version: TM1 11
Excel Version: 365
Post by WilliamSmith »
As an alternative, have you tried just scripting out the PDF export using built in VBA functions? e.g.
ActiveWorkbook.ExportAsFixedFormat Type:=xlTypePDF, Filename:=saveLocation
