need help with nested syntax
kbogies
Version: 9.1sp4 64x
Post by kbogies »
hi all,
hope someone can point out what i'm doing wrong here... my eyes are melting :?
i tried breaking the formula down to it's simplist state of an IF statement, so don't mind the results of "1" if true, "2" if false...
['Ultimate RPC Ratio'] = IF(DB('WP Actual Reporting', !BPF Strategy, !WPMetrics,
ATTRS('BPF Product',!BPF Product, 'LOB'), !BPF Term, !WPChannel, !BPF State,
!WPEvalPeriod, !WPEffectivePeriod) = 'Auto', 1, 2);
'WP Actual Reporting' is the name of the cube, with all the dimensions listed
['Ultimate RPC Ratio'] is an element of the WPMetrics dimension.
LOB is a text attribute of the BPF Product dimension, populated with results of: 'auto', 'property', or ' '.
i keep getting an error message for the bold section at the end, saying that it's "incorrect logical comparison".
mattgoff
Version: 10.2.2.6
Excel Version: O365
Re: need help with nested syntax
Post by mattgoff »
Unless it's a posting/retype error, you're missing the @ before the = in your string compare.
kbogies
Version: 9.1sp4 64x
Post by kbogies »
thank you, thank you mattgoff! i'm still new at rule writing and always forget about the "@"....
Post by David Usherwood »
May I also offer the following layout suggestion:
  IF(
  !BPF Term, !WPChannel, !BPF State,!WPEvalPeriod, !WPEffectivePeriod) @= 'Auto',
  1,
#else
  2
I'm currently working on converting a 31 tab excel workbook into a TM1 model and found that in one tab, the contents of _each cell_ filled a single page in Word - and of course it was unformatted.
