MDX Filter By Current Member Value Range
kenship
OLAP Product: Cognos
Version: Planning Analytics 2.0.7
Post by kenship »
I'm trying to write a MDX filter statement to return years from 2018 to upcoming budget year (say 2024 for now).
This one works.
vIndexDim = 1;
WHILE(TABDIM(vCube, vIndexDim) @<> '');
	vDimName = TABDIM(vCube, vIndexDim);
	SubsetDestroy(vDimName,vSubset);
	IF( vDimName @='Year');
	vMDX= '	{FILTER
			TM1FILTERBYLEVEL (
					      TM1DRILLDOWNMEMBER( {[' | vDimName| '].[(ALL YEARS)]}, ALL, RECURSIVE)
					    ,0
			,StrToValue ( [' | vDimName| '].currentmember.name )>2017
			 AND
			 StrToValue ( [' | vDimName| '].currentmember.name )<= 2024
ELSE;
	vMDX = '{TM1FILTERBYLEVEL( TM1SUBSETALL( [' | vDimName | ']), 0)}';
               ENDIF;
SubsetCreateByMDX(vSubset, vMDX);
	ViewSubsetAssign(vCube, vView, vDimName, vSubset);
	vIndexDim = vIndexDim +1;
END;
What I want to do is to change 2024 to become a variable, and I added:
pCurrentBudgetYear = StringToNumber(CellGetS('Control','Current Budget Year', 'svalue'));
What I would like to know is how to change the upper range statement to replace 2024.
Thanks!
Kenneth
MarenC
Excel Version: Excel 2016
Re: MDX Filter By Current Member Value Range
Post by MarenC »
You haven't exactly explained what your issue is?
Have you tried adding in pCurrentBudgetYear to your logic, so something like the following:
StrToValue ( [' | vDimName| '].currentmember.name )<=' | NumberToString( pCurrentBudgetYear )
Maybe you could just reference the control cube in the MDX as follows:
{FILTER
			TM1FILTERBYLEVEL (
					    ,0
			,VAL ( [' | vDimName| '].currentmember.name )>2017
			 AND
			 VAL ( [' | vDimName| '].currentmember.name )<= VAL( [Control].([Name of dim].[Current Budget Year],[Name of dim].[svalue]) )
I prefer using VAL to STRTOVALUE is situations like this.
Maren
kenship
Post by kenship »
It works already!
My earlier attempt resulted in wrong expression or ambiguity issue with other dimensions.
Thanks a lot!!
