Anyone Know what is difference between IBM Cognos tm1 9.1 and IBM Cognos tm1 11.6 <PA2.0.9> Version ?
I mainly want to know usability , such as Websheet function / RULE function / TI function , Any aspects what is frequently-used?
what is difference between TM1 9.1 and TM1 11.6
Re: what is difference between TM1 9.1 and TM1 11.6
Are you talking about 15 years ago ?
9.4 introduced Unicode. You really can't compare the two
MarenC
- Excel Version: Excel 2016
Give me three years to collate the information and I will get back to you.
In the meantime, you might want to look at this (which give you a couple of years of changes to chew over):
https://www.tm1forum.com/viewtopic.php?t=13186
Maren
Maren
You do realize that TM1 9.1 came out in 2007?
Niko
- Version: PA 2.09 / TM1 11.7.00000.42
- Excel Version: EXCEL 2019
Sorry,i don not know it was released 15 years ago,i want to know whether it can also be used to develop new module like cost budget / forecast analysis,etc.
- qml
- Excel Version: 2007 - 2016
Yes, you can use a very old version of TM1 to develop a budgeting/forecasting application. The question is: why would you want to? You'd be missing out on 15 years of improvements and any ongoing vulnerability and defect fixes. You'd probably have to upgrade some expired certificates to get it to work and make sure all other software components you need are also old enough to work with that version. It's a bit like using Windows Vista in 2023. You certainly can if you really, really want to.
Kamil Arendt
