quote issue on a MDX TurboIntegrator function
sblot
Version: 2.0.82
Post by sblot »
I would like to create a MDX subset in my TurboIntegrator process, with an attribute variable. But I have a quote issue.
Let's illustrate with an example:
This code works well:
vMDX = '{FILTER(TM1SubsetAll([vDimension1].[vDimension1]), ([vDimension1].[vDimension1].CURRENTMEMBER.PROPERTIES("vAttribute1") = "vValue"))}';
vSubsetName1='zSubSet_' | vDimension1;
SubsetCreatebyMDX(vSubsetName1,vMDX);
SubsetMDXSet(vDimension1,vSubsetName1,'');
DataSourceType='SUBSET';
DatasourceNameForServer=vDimension1;
DatasourceDimensionSubset=vSubsetName1;
Now, I would like to use a variable on my "vValue", so i wrote:
vMDX = '{FILTER(TM1SubsetAll([vDimension1].[vDimension1]), ([vDimension1].[vDimension1].CURRENTMEMBER.PROPERTIES("vAttribute1") = ' | vValue | ' )}';
But the result is wrong, because my code does not have the vValue between quotes. It generates: {FILTER(TM1SubsetAll([vDimension1].[vDimension1]), ([vDimension1].[vDimension1].CURRENTMEMBER.PROPERTIES("vAttribute1") = vValue))}
I guess there is a simple solution, but I don't have it. Do you have any clue?
Have a nice day.
sblot
burnstripe
Version: 2.0.9
Re: quote issue on a MDX TurboIntegrator function
Post by burnstripe »
Change the syntax to this
vMDX = '{FILTER(TM1SubsetAll([vDimension1].[vDimension1]), ([vDimension1].[vDimension1].CURRENTMEMBER.PROPERTIES("vAttribute1") = "' | vValue | '" )}';
Notice the double quote before the single quote before vvalue and a double quote after the following single quote
Another approach to consider is using Expand() - This makes these MDX queries easier to read by limiting all the quotes needed:
vMDX = Expand('{FILTER(TM1SubsetAll([vDimension1].[vDimension1]), ([vDimension1].[vDimension1].CURRENTMEMBER.PROPERTIES("vAttribute1") = "%vValue%")}');
BR, George.
+1 I would also always use Expand for such cases. It's just easier.
sblot
Version: 2.0.82
Post by sblot »
Thank you burnstripe, it is working well now.
I did not know this expand function. I will try it so, thanks for the tip.
MarenC
Excel Version: Excel 2016
Post by MarenC »
My advice, learn it!
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
Always use EXPAND() as well. Makes parsing more complex MDX easier to read vs. concatenations to me.
Ty
Cleveland, TN
Just pay attention to 2 things:
- Expand with numbers gives you a certain format with 3 decimal digits
- Expand of an Expand whereby the inner Expand resolves to something that contains a % character will cause you headaches.
