Hello
Not sure which section I should put this question.
What I am trying to do is create a macro to commit data into Pax rather than the function in the addin. Has anyone ever done this?
Thank you
VBA code to Commit data in pax via Macro
Mithun.Mistry1103
- OLAP Product: cognos
- WilliamSmith
- OLAP Product: TM1 / PA / PAx / PAW
- Version: TM1 11
- Excel Version: 365
Re: VBA code to Commit data in pax via Macro
Hi there,
I've been able to prototype writing into TM1 using the REST API with VBA. Would love to discuss further.
Sub Example()
'Configure element list (Dimension~Hierarchy~Element)
Dim elementList As New Collection
Set elementList = Nothing
elementList.Add "MONTH~MONTH~2212"
elementList.Add "DAY~DAY~19"
elementList.Add "MEASURE~MEASURE~MEASURE1"
TM1_Write_to_Cube "IntRate", elementList, newMeasureValue
End SubCode: Select all
Sub TM1_Write_to_Cube(cubeName As String, elementList As Collection, newValue As String)
Dim payload As String
payload = "{""Cells"":[{""Tuple@odata.bind"": ["
For Each element In elementList
payload = payload & """Dimensions('" & Split(element, "~")(0) & "') / Hierarchies('" & Split(element, "~")(1) & "') / Elements('" & Split(element, "~")(2) & "')"","
Next
payload = payload & "]}],""Value"":""" & newValue & """}"
response = TM1_Post("/api/v1/Cubes('" & cubeName & "')/tm1.Update", payload)
End Sub
Function TM1_Post(endPoint As String, payload As String)
Dim x As MSXML2.ServerXMLHTTP60
Set x = New MSXML2.ServerXMLHTTP60
x.Open "POST", "https://your_tm1_server_host:your_tm1_server_port" & endPoint, False, "your_username", "your_password"
x.setRequestHeader "WWW-Authenticate: Basic Realm", "TM1"
x.setRequestHeader "Content-Type", "application/json"
x.SetOption 2, 13056
x.Send payload
TM1_Post = x.responseText
End Function
