Had a template that I needed to run TM1 Print Report on, but kept failing with "Print Report-Delete method of Worksheet class failed" - turned out to be a sheet that was flagged as Visible:=2-xlSheetVeryHidden.
Changed to visible and deleted in my case-all fine now.
Seemed fine if set to 0-xlSheetHidden but Print Report does not like xlSheetVeryHidden.
- Excel Version: 365
Re: Delete method of Worksheet class failed
Thank you so much for this postings. It's very helpful. It worked for me when I changed the Visible to "0-xlSheetHidden" on the "Cognos_Office_Connection_Cache" which was not visible. It only shows on the VBA window of Developer menu.
Here is a VBA solution. I give it to my customers from a button in the Excel QAT (Quick Access Toolbar). Then it's right at their fingertips.
Sub Delete_hidden_sheet()
'Wim Gielis
'October 2022
'delete a specific worksheet that would otherwise make the TM1 Report Manager (TM1 Perspectives) choke and raise an error
Dim ws As Worksheet
'continue without stopping when errors are encountered
On Error Resume Next
Set ws = ActiveWorkbook.Worksheets("Cognos_Office_Connection_Cache")
If Not ws Is Nothing Then
'make the sheet visible
ws.Visible = xlSheetVisible
'delete the sheet without alerts
Application.DisplayAlerts = False
ws.Delete
Application.DisplayAlerts = True
End If
On Error GoTo 0
End Sub
Or, if you prefer a more condensed notation:
With ActiveWorkbook.Worksheets("Cognos_Office_Connection_Cache")
.Visible = -1
.Delete
End With
On Error GoTo 0
End Sub
