rule save time wait problem
mrdauduong
Version: PA 2.0.74.23
Excel Version: Excel 2016
Post by mrdauduong »
hi,
i have a client who have some cube with a lot of rules with 1 big dimension (2 millions elements) and some other small dimension.
the problem today is i have to wait at least 5 hours for save rules if i change something in rule editor (and for make new rule or make a correction, i have to test a lot)
any tips to reduce the waiting time of save rule in this case? :?
thank a lof for help.
Cross-posted in IBM community : https://community.ibm.com/community/use ... 4eda43146b
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: rule save time wait problem
Post by BariAbdul »
MarenC
Post by MarenC »
Someone appears to have thrown you in at the deep end, my sympathies!
Looking at all your posts, it seems to me you are trying to run before you can walk, no wait you are trying to enter the 100m Olympic final before you can walk!
Can any of the rules be turned into TI processes, if you don't know what a TI process is, this might help:
https://www.ibm.com/docs/en/planning-an ... tor-basics
Maren
Quick and dirty for testing new rules etc could be to remove nearly all the data, except that which you need to proove out rule changes.
Depends if are you trying to solve "I need to get these rules written and tested" or "How to improve the compile time of the rules" As others have indicated the latter can be one of the most challenging jobs.
Good luck!
mrdauduong
thank for this, i will read all that
mrdauduong
they dont want TI process, they have the biggest VM in the world and they dont want something fast and simple :?
they just want a calcul direct when they type something :mrgreen:
MarenC wrote: Thu Oct 06, 2022 4:08 pm Hi,
Maren
mrdauduong
i dont have trouble with writing rule, just want to know how to improve the compile time of rule and there post below is good enough !! thank !!
Steve Rowe wrote: Thu Oct 06, 2022 4:46 pm Quick and dirty for testing new rules etc could be to remove nearly all the data, except that which you need to proove out rule changes.
Good luck!
MarenC
Post by MarenC »
One important piece of advice, sometimes difficult conversations with the clients are necessary!
I mean when they make tea in the morning they have to click a button right? :roll:
Maren
mrdauduong
thank Maren, i try again and again to convient them to use TI for complexe rule and i can do a TI that can work well with only 5 secondes waiting time. but they dont want to...they want to something complexe to make his life simplifier... :mrgreen: :mrgreen: :mrgreen:
MarenC wrote: Fri Oct 07, 2022 7:22 am Hi,
Maren
