I have a line item dimension with the elements from 1 to 100. I'd like to give a user an ability to select the first 5, 10, ext. elements on the websheet. The dimension is used in the allocation cube, so one value can be allocated to three line items or five, or fifteen. The number should be flexible. I know about TOPCOUNT function, but it's based on the values, which is not what I need. Is there an MDX function that can be applied to the dimension subset to select as many elements as needed?
How to select a given number of elements from the dimension?
- 20 Ton Squirrel
- Version: Planning Analytics with Watson
Re: How to select a given number of elements from the dimension?
You could also set up a number of subsets beforehand, just name each subset according to their selection. A TI process could do a one-time automation of that tedium.
Declan's response is far more efficient, though, I must admit.
War teaches us geography, getting old teaches us biology.
