TM1Top for versions pre 8.4.4
TomBr
Post by TomBr »
Does anyone know if the 8.4 version of TM1Top works with versions before 8.4.4 - 8.4.2 to be precise.
While the accompanying documentation suggests it only works with versions from 8.4.4 onwards I have come across references to earlier versions elsewhere.
Any help appreciated.
Tom
BigDSter
Version: 9.4.1
Re: TM1Top for versions pre 8.4.4
Post by BigDSter »
We used it on 8.4.3 for sure, never went to 8.4.2 though.
David Newton
Burtons Foods
jim wood
Version: PA 2.0.7
Post by jim wood »
I think you might be able to use it in earlier versions but if it does cause a crash Cognos will not offer a solution,
I think that it was available in 8.4.3 but you could not terminate a thread using it. From memory 8.4.3 was the first version it was available for'
HTH, Steve
TomBr
Post by TomBr »
Thanks for all the input. Having finally got a chance to test this, it appears not to work with version 8.4.2 - it comes up with a dll error about not finding an entry point which seems ominous.
Tom
