How to calculate up to Millisecond
Firefly007
OLAP Product: PA,PAW
Version: PA 2.0, PAW(2059)
Excel Version: Excel 2010
Post by Firefly007 »
I was able to get value only up to seconds . can we calculate up to Milliseconds ?
V1= Now;
V2=TIMST(V1, ' \H\p \imin\ssec');
Re: How to calculate up to Millisecond
What does the documentation say?
Firefly007
In the documentation I could not find calculation upto Milliseconds. The least i was able to find only upto seconds.
Firefly007 wrote:In the documentation I could not find calculation upto Milliseconds. The least i was able to find only upto seconds.
Are you really talking about calculating to milliseconds, or displaying milliseconds?
What, in short, is your intent?
The TM1 system does go down to millisecond level as you can see from some of the performance manager cubes; whether you can rely on the accuracy of that is another matter.
Have you read this post on dates and times? If so, you should be aware that milliseconds are merely represented by decimal places way out to the right.
There is not (as far as I'm aware) a TM1 formatting code for converting them into a string showing milliseconds but it should be easy enough to work out how to do so when you understand how the values are stored. But again it depends on whether your intention is calculation or display.
Firefly007
I went through the link which you have provided. I still cannot figure out how to display upto milliseconds. I am trying to append the timestamp to an ascii output file.
This one displays only upto seconds as given in document.
Firefly007 wrote:I went through the link which you have provided. I still cannot figure out how to display upto milliseconds. I am trying to append the timestamp to an ascii output file.
That does quite surprise me given that I had already said:
I wrote:There is not (as far as I'm aware) a TM1 formatting code for converting them into a string showing milliseconds
and then went on to add:
I wrote:but it should be easy enough to work out how to do so when you understand how the values are stored.
I'm sure that you took the time to carefully read the article that I referred you to, but it's possible that you missed one of the key points so allow me to elaborate.
A day is represented by the value 1. This is 24 hours, or 1,440 minutes, or 86,400 seconds, or 86,400,000 milliseconds.
If you were to take the decimal component of the value returned by Now() (that is, as the article explains, the time component of the value), you would have the decimal fraction of the day that has elapsed so far. This value can be manipulated in various ways.
1/24 represents the number of hours in a day, yes? So you could divide the decimal component of Now() by (1/24), then take the integer of that to get the number of completed hours so far in the day.
If you want to get the number of completed minutes since the start of the day instead, replace (1/24) with (1/1440).
If you want the number of completed minutes in the current hour, take the number of completed minutes, and subtract (the number of completed hours * 60).
Are you seeing the pattern?
It is possible that someone has already written the necessary code to extract the number of milliseconds, and that they will eventually post it which you can then use without any effort.
But in the absence of that, if you follow the calculation methods above you will be able to calculate down to the number of milliseconds for yourself, then just convert that value to a string.
Incidentally, if you are writing so many log files that they need to be separated down to the millisecond... you may well be adversely affecting TM1's performance. Writing to disk is (relatively) slow (certainly compared to in memory operations) and therefore something to be done sparingly. If you're doing it so often that a timestamp down to the second isn't sufficient, it may be worth rethinking what you're doing and why.
rmackenzie
Post by rmackenzie »
Firefly007 wrote:I was able to get value only up to seconds . can we calculate up to Milliseconds ?
V1= Now;
It's also worth bearing in mind this nugget of information that Duncan posted about:
Duncan P wrote:Although NOW may return a number that looks very precise the granularity is in fact one second.
So although you may be able to get the current time at the precision of milliseconds, it may be a piece of information that you are not able to really use in a meaningful way. What are you trying to do with the timestamp?
Robin Mackenzie
V1= Now;
Interesting; Duncan appears to be correct (not that I'd doubt it). But out of curiosity I ran some similar tests. The value returned certainly has the precision (1/86,400,000 of a day (1 millisecond) has its first significant digit at the 8th decimal place, and the Now() function returns far more than that), but the problem is the accuracy. (As I'd referred to in my first reply, but I didn't realise that it was as bad as this.) The value returned doesn't seem to be updated / read from the system clock in real time but only periodically; as Duncan observed, most likely each second or so. As a result you can be banging away retrieving timestamps constantly and get the same value for most of any given second.
rmackenzie wrote:What are you trying to do with the timestamp?
That was mentioned in their last reply:
Firefly007 wrote:I am trying to append the timestamp to an ascii output file.
As I said in my last one, if you need AsciiOutput timestamps down to the millisecond... the process that calls for that may be worth reviewing.
Firefly007
Sorry for responding late.
The purpose for this milliseconds was to check for flags files to save data to disk depending on the time stamp.I had four process which run in parallel.i was using test data which caused four process to complete almost same seconds so i was trying go up to milliseconds. how ever it was not the scenarios when i went with complete data set . for now I am good up to seconds. Thank for your help.
macsir
Version: PAL 2.0.9
Post by macsir »
Just want to share, now it is possible in Planning Analytics with function HierarchyTimeLastUpdated. It is not perfect as you have to create a dummy hierarchy to get millisecond. It would be nice to have a native function with millisecond format.
This function indicates when a speci®ed dimension hierarchy was last updated.
The function returns a real number that represents the current day (including the hour, minute, second,
and millisecond) since the beginning of the year 1900.
This is a TM1 TurboIntegrator function, valid only in TurboIntegrator processes.
Syntax
HierarchyTimeLastUpdated(dimension, hierarchy);
Argument Description
dimension The name of the dimension.
hierarchy The name of the hierarchy.
Example
HierarchyTimeLastUpdated('Region', 'Europe');
This example returns information on when the Europe hierarchy of the Region dimension was last
updated. If a value of 42548.<hours>.<minutes>.<milliseconds> is returned, you can divide 42548 by
365 to obtain (approximately) 116.
When added to the started of 1900, the result is a current year of
2016.
ichermak
OLAP Product: TM1 / IBM Planning Analytics
Version: 2.0.9.10
Excel Version: 2019
Post by ichermak »
There seems to be a problem with the HierarchyTimeLastUpdated function, which does not return a correct value for hours.
Here is the test I performed:
If(DimIx('}Clients', Tm1User) = 0); cTM1User = 'Chore'; Else; cTM1User = Tm1User; EndIf;
cStartTime = Now;
cProcessName = GetProcessName;
cIdExecution = cProcessName | '_' | TimSt(cStartTime, '\Y\m\d\h\i\s') | '_' | cTM1User  | '_' | Fill( '0', 5 - Long(NumberToString(Int(Rand * 65536)))) | NumberToString(Int(Rand * 65536));
cDebugFile = GetProcessErrorFileDirectory | cIdExecution | '.dbg';
nMax = 1000;
nIndex = 0;
While(nIndex <= nMax);
    nIndex = nIndex + 1;
    # Creation of temp hierarchy to use HierarchyTimeLastUpdated as it's the only way to get milliseconds for the acutal version of planning analytics
    cTempDimName = 'Dim_' | cIdExecution;
    cTempHierName = 'Hier_' | cIdExecution;
    If(DimensionExists('DimName') = 1);
        DimensionDestroy(cTempDimName);
    EndIf;
    DimensionCreate(cTempDimName);
    HierarchyCreate(cTempDimName, cTempHierName);
    # Need to subtract 21916 wich correspond to the serial date of 01/01/1960 starting from 01/01/1900 as date time function are based on serial date starting from 01/01/1960
    nDateTime = HierarchyTimeLastUpdated(cTempDimName, cTempHierName) - 21916;
    nNowDateTime = Now();
    nHour = TIMVL(nDateTime, 'H');
    nMinute = TIMVL(nDateTime, 'I');
    nSeconde = TIMVL(nDateTime, 'S');
    nMillisecond = 86400000 * (nDateTime - INT(nDateTime) - (nHour * (1 / 24)) - (nMinute * (1 / 1440)) - (nSeconde * (1 / 86400)));
    sMillisecond = NumberToString(nMillisecond);
    sTimeStamp = TimSt(nDateTime, '\Y-\m-\d \h:\i:\s') | '.' | sMillisecond;
    nNowHour = TIMVL(nNowDateTime, 'H');
    nNowMinute = TIMVL(nNowDateTime, 'I');
    nNowSeconde = TIMVL(nNowDateTime, 'S');
    nNowMillisecond = 86400000 * (nNowDateTime - INT(nNowDateTime) - (nNowHour * (1 / 24)) - (nNowMinute * (1 / 1440)) - (nNowSeconde * (1 / 86400)));
    sNowMillisecond = NumberToString(nNowMillisecond);
    sNowTimeStamp = TimSt(nNowDateTime, '\Y-\m-\d \h:\i:\s') | '.' | sNowMillisecond;
    ASCIIOutput(cDebugFile, sTimeStamp, sNowTimeStamp);
End;
Result:
"2021-07-13 16:26:08.62,99989112","2021-07-13 18:26:08.0,000040047"
Do you guys see an error in my logic?
ichermak wrote: Tue Jul 13, 2021 4:44 pm There seems to be a problem with the HierarchyTimeLastUpdated function, which does not return a correct value for hours.
cStartTime = Now;
nMax = 1000;
nIndex = 0;
    EndIf;
End;
Result:
Not a function I have had any need to use before but looking at the 2 hour difference I would hazard a guess that it is returning GMT, which is the default logging time unless otherwise specified in the log properties. This only only holds true if the TM1 Server's OS is 2 hours out from GMT when you were running this test? e.g. most of Europe at the moment.
macsir
Version: PAL 2.0.9
Post by macsir »
Yes, I agree with declanr. DimensionTimeLastUpdated and HIERARCHYTIMELASTUPDATED need to be converted from GMT time to local time.
#If converted to local time, need to add 10 / 24 for hour difference
vDateTimeWithMillisec = NUMBERTOSTRING((DimensionTimeLastUpdated(DimName)) + 10/24);
ichermak
Version: 2.0.9.10
Excel Version: 2019
Post by ichermak »
Thank you for your answers!
It is indeed related to the fact that HierarchyTimeLastUpdated is based on GMT.
In my case, I think the best way to handel it is to use HierarchyTimeLastUpdated only to get the milliseconds part of a time.
Working in Milliseconds comes up every once in a while so thought that it may be useful to highlight the undocumented Millitime() function.
nStart=Millitime();
Sleep(500);
nEnd=Millitime();
nDuration=nEnd-nStart;
asciioutput('debug.txt', NumberToString(nStart), NumberToString(nEnd), NumberToString(nDuration));
Output file contains:
"73712166","73712676","510"
So there is a little bit of overhead in executing the sleep and setting the nEnd variable but the 500 millisecond delay can be seen.
Similarly, setting sleep to something higher like 54321 gives me:
"73933351","73987683","54332"
HTH
P.S. I have not tried much to break the serial down to see what the seed is or how it relates to a normal date/time serial, if at all. Happy for someone to play and let us know.
Disclaimers: PAW does not know anything about Millitime and will not compile. As with all undocumented items, IBM will advise not to use in Production, if ever etc. etc. etc.
BR, George.
gtonkin wrote: Fri Dec 10, 2021 9:48 am Disclaimers: PAW does not know anything about Millitime and will not compile. As with all undocumented items, IBM will advise not to use in Production, if ever etc. etc. etc.
Well SLEEP and BREAK are also undocumented
so ¯\_(ツ)_/¯
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
It's always worth pushing it to see what the tick granularity actually is, i.e. if you are hammering it continuously how often does the returned value actually change. That was how we found out how bad NOW is. Millitime certainly looks a lot better, but if you are using it for micro-benchmarking it's better to know for sure.
Duncan P wrote: Tue Dec 14, 2021 7:16 am It's always worth pushing it to see what the tick granularity actually is, i.e. if you are hammering it continuously how often does the returned value actually change...
Let us know what you find.
Also, for others, this function may be useful in combination with TM1User to create unique views, subsets etc.
BR, George.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
George, another function pulled from your magic hat! Thanks
