Hello All,
I have a dimension in TM1 Web, which has more than 400 pages of elements as shown in this image :
https://ibb.co/xjgBfh3
I want to select all of them and drag them to the next selection tab at the left of the screen, so they can be displayed in the cube. I used Shift + Click like in excel or in TM1 Architect but it seems it is not working for Web.
Any idea how I can achieve this ?
TM1 Web select many elements at the same time
pikolikoli
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 2013
ascheevel
- Version: PA 2.0.9.1
- Excel Version: 365
Re: TM1 Web select many elements at the same time
If you're trying to select 400+ elements from the left side and drag to the right, I'd say you're not using the subset editor in the best way in TM1Web. One thing I like to do when working with the TM1Web subset editor is to simply collapse the left side and work only in the right. Select the subset you want, or simply show all elements, and then do any filtering/searching all on the right side.
pikolikoli
- OLAP Product: tm1
- Version: 10.2
Thank you So much! I feel bad for not thinking about thisascheevel wrote: ↑Thu Oct 28, 2021 1:45 pm If you're trying to select 400+ elements from the left side and drag to the right, I'd say you're not using the subset editor in the best way in TM1Web. One thing I like to do when working with the TM1Web subset editor is to simply collapse the left side and work only in the right. Select the subset you want, or simply show all elements, and then do any filtering/searching all on the right side.
ascheevel
There are many times in one's life to feel bad about something. Determining that a current method is suboptimal and seeking to better yourself by sharing your frustration and soliciting advice from an online community of users who may have experienced the same frustration is not one of them.
pikolikoli
- OLAP Product: tm1
- Version: 10.2
You are totally rightascheevel wrote: ↑Tue Nov 16, 2021 3:52 pmThere are many times in one's life to feel bad about something. Determining that a current method is suboptimal and seeking to better yourself by sharing your frustration and soliciting advice from an online community of users who may have experienced the same frustration is not one of them.
