Import Views without restart
pikolikoli
OLAP Product: tm1
Post by pikolikoli »
Hello All,
is there a way to import views to TM1 without having to restart the server ?
I tried today to put all my views in TM1DATA but I wasnt able to see them under the cubes.
macsir
Version: PAL 2.0.9
Re: Import Views without restart
Post by macsir »
put views under correct folder and unload/reload the cube to show them.
pikolikoli
OLAP Product: tm1
Thank you for your replay. I right clicked on the cube and I only found unload button , where can I find the reload button ?
pikolikoli wrote: ↑Tue Aug 03, 2021 8:52 am Thank you for your replay. I right clicked on the cube and I only found unload button , where can I find the reload button ?
Unloaded cubes are automatically reloaded the first time they're queried. It doesn't need to be done manually.
All you need to do is double click on it to launch the default view and trigger the load.
pikolikoli
OLAP Product: tm1
I didnt know that .. Thank you So much for the clarifications . I appreciate it.
If I understand it correctly, I could copy paste an existing public view and rename it. Optionally, edit the vue file contents and change the year for example in the Year dimension. When with unload and reload the public view would be visible ? Not sure if that will work. At least I cannot in the latest version of PAL in Architect.
