Register process via RestAPI
- orlando
- Version: PAL 2.0.8
Hello all,
is there a clever and quick way to register a process in a data model via the RestAPI if I have copied the process file from another data model - I would like to avoid restarting the database.
I found the command Process.Compile in IBM's RestAPI documentation - unfortunately IBM does not elaborate on this.
Or is there another way to achieve the goal?
I am happy about links and hints
TM1Py is currently not a solution, as I cannot install Python on my computer (long story).
Many greetings
orlando
Many greetings
orlando
- Version: All
- Excel Version: All
Re: Register process via RestAPI
There are a few ways you 'could' do it quickly but it may be necessary to find out how you can do it first and then find a preferred method.
Are you able to install a REST Api Client like Postman? Do you have access to Powershell? Do you have access to ScriptLab in excel?
- scrumthing
- Version: 11.x
- Excel Version: MS365
I think your main problem is that you have the process file which is not in the format the rest api would expect. For the rest api to accept your ti you would have to extract all necessary information from the file and create the json file which the rest api expects. If it is just code without parameters and variables and a data source that can be done easily. You could use the hidden property 'code' in the current tm1 version (which version are you on?) which should allow you to send over just the ti-code (the format is similar to the one which the git integration provides).
If you have a more complex code you should extract the proper json via the rest api (instead of copying the file) either by starting a local tm1 server or by extracting it from the source.
Hope that helps...
Hope that helps...
- macsir
- Version: PAL 2.0.9
I would suggest you to setup a new instance where you put all your process files. And In powershell, use Invoke-RestMethod to call the process endpoint to copy all processes over from the new instance. The syntax should be the same as what's been used in TM1py.
- orlando
Hi,Edward Stuart wrote: ↑Thu Apr 08, 2021 7:55 am There are a few ways you 'could' do it quickly but it may be necessary to find out how you can do it first and then find a preferred method.
Postman & Powershell are available. Script Lab is new to me.
orlando
- orlando
Hi,scrumthing wrote: ↑Thu Apr 08, 2021 7:19 pm I think your main problem is that you have the process file which is not in the format the rest api would expect. For the rest api to accept your ti you would have to extract all necessary information from the file and create the json file which the rest api expects. If it is just code without parameters and variables and a data source that can be done easily. You could use the hidden property 'code' in the current tm1 version (which version are you on?) which should allow you to send over just the ti-code (the format is similar to the one which the git integration provides).
Hope that helps...
what's the "hidden property code". We are using version 2.08 an 2.09.
It will be more complex code.
orlando
- orlando
Hi,macsir wrote: ↑Thu Apr 08, 2021 8:31 pm I would suggest you to setup a new instance where you put all your process files. And In powershell, use Invoke-RestMethod to call the process endpoint to copy all processes over from the new instance. The syntax should be the same as what's been used in TM1py.
I can already see that the idea of simply copying the process, calling RestApi and registering the process will not work.
I found this: https://www.youtube.com/watch?v=EWltFli9yBA
Something like this would be enough for me, unfortunately he only shows and does not explain how he did it
best regards
orlando
- scrumthing
- Version: 11.x
Check this out... https://github.com/bgregs514/vscode-tm1 ... -786979805
- Excel Version: 2017
i think it is better not copy the file hardly...When you have knowledge of REST API then call RestAPI Command to get Process Definition from SourceServer and then take these JSON Result and push it to your Target Server.
I'm built that exactly in a ASP.NET Web Tool and these works. Copy from Left (Source) to Right (Target) Server. Advantage is, that is automatically registered and usable on the Target server.
When you more help then let it know.
- Version: 2.0
To register an absolute bare-bones process, the api call would simply be:
and then just attach a basic JSON structure to the post call:
And that's it! Obviously there are more attributes like Parameters and Datasouce that can be added, but I would recommend setting up the above as a "template", pulling it into a JSON object, and then adding additional parameters to the object - it's just much easier to operate on an object programmatically, than it is to hack together a template file.
POST/ <api_url>/Processes
"Name": "",
"PrologProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****",
"MetadataProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****",
"DataProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****",
"EpilogProcedure": "\r\n#****Begin: Generated Statements***\r\n#****End: Generated Statements****"
I haven't experimented with it (yet) but would be PAFE API be an alternative ? In the end it's VBA so not terribly difficult (I assume
There's code here: https://ibm.github.io/paxapi/#rest-api
- orlando
Hi,MNI wrote: ↑Fri Apr 09, 2021 3:12 pm Hello,
I think that is exactly what I have in mind as a long-term goal. If possible as a web application.
So little time - so many things you could "build".
orlando
- orlando
and now in englishWim Gielis wrote: ↑Sat Apr 10, 2021 2:27 pm Hi,
I haven't experimented with it (yet) but would be PAFE API be an alternative ? In the end it's VBA so not terribly difficult (I assume)
could be. I'll take a closer look.
Best regards
orlando
Rest API is much better tested, more complete and more stable than PAfE API. Best bet is to use Rest API via VBA. There will be a bit of effort in parsing MDX and transforming json response to tabular format but way less headaches overall.
