Creating Dimensions Using Referentials .How does i work ?Where to learn about it
pikolikoli
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 2013
Hello Everyone,
I saw some people use referentials to create dimensions and it's elements. Basicaly from what I understood the referential is a worksheet where they declare the dimensions and its simple element , comsolidated elements,attributes ...etc.
I would Like to know what is the steps we should follow to create the referenciel ? Does it have another name , a known name defined by IBM documentation so I couldlook it up ?
Also after creating this referencial how can we execute it to create the dimensions ? I only know that they dont use processes to import this sheet.
If there is any ressources where I can learn about it to understand it please share it with me it will help alot.
Thank you
Thank you
Re: Creating Dimensions Using Referentials .How does i work ?Where to learn about it
I don't know where the hell you picked up the name "referential" from, but what you're referring to is an .xdi. An .xdi is a standard Excel workbook (in any format; .xls. xlsx, .xlb or whatever) with a non-standard file extension. (Specifically, .xdi.) They are described here.pikolikoli wrote: ↑Wed Jan 20, 2021 9:36 am I saw some people use referentials to create dimensions and it's elements. Basicaly from what I understood the referential is a worksheet where they declare the dimensions and its simple element , comsolidated elements,attributes ...etc.
Note that they will not work for you if you are using alternative hierarchies in the PA2 sense of the term. For a classic dimension with roll-ups, they're fine and sometimes better than the alternatives. Unless, that is, you are using 64 bit Excel in which case you may hit some issues as described here.
TM1 ribbon, Developer group -> Dimension Save.pikolikoli wrote: ↑Wed Jan 20, 2021 9:36 am Also after creating this referencial how can we execute it to create the dimensions ? I only know that they dont use processes to import this sheet.
See the link above.pikolikoli wrote: ↑Wed Jan 20, 2021 9:36 am If there is any ressources where I can learn about it to understand it please share it with me it will help alot.
pikolikoli
- OLAP Product: tm1
- Version: 10.2
Alan Kirk wrote: ↑Wed Jan 20, 2021 9:43 amI don't know where the hell you picked up the name "referential" from, but what you're referring to is an .xdi. An .xdi is a standard Excel workbook (in any format; .xls. xlsx, .xlb or whatever) with a non-standard file extension. (Specifically, .xdi.) They are described here.pikolikoli wrote: ↑Wed Jan 20, 2021 9:36 am I saw some people use referentials to create dimensions and it's elements. Basicaly from what I understood the referential is a worksheet where they declare the dimensions and its simple element , comsolidated elements,attributes ...etc.
Thank you So much Alan. This is very helpfull
The naming 'Referentiel' is what is used in some companies. I think it is a key word used by clients so it became a norme I guess.
Thank you
Could it be that you're a French speaking person natively ?pikolikoli wrote: ↑Wed Jan 20, 2021 11:15 amThank you So much Alan. This is very helpfull
Thank you
That's a really interesting point; though if that is the case, it didn't come from IBM's documetah-sion Frans-aise:Wim Gielis wrote: ↑Wed Jan 20, 2021 9:35 pmCould it be that you're a French speaking person natively ?pikolikoli wrote: ↑Wed Jan 20, 2021 11:15 amThank you So much Alan. This is very helpfull
Thank you
Je ne parle pas très bien français (except for that last sentence, "parlez vous anglais", and "parlez vous italien", which I know by heart), but if Google Translate is to be trusted (which I know from Italian it frequently isn't):Une feuille de dimension est une feuille de calcul Microsoft Excel modifiée, dans laquelle vous répertoriez les éléments et les relations hiérarchiques pour une dimension. TM1 enregistre les données de la feuille de dimension dans deux fichiers : la feuille de dimension (dimname.xdi) et le fichier compilé (dimname.dim).
I can find only three uses of the word "référentiel" in the IBM French documentation, and all of them relate to TM1 Web. I suppose that an .xdi is a form of repository, but it seems to be a stretch of the term. However as I said... Je ne parle pas très bien français.A dimension sheet is a modified Microsoft Excel worksheet, in which you list the items and hierarchical relationships for a dimension. TM1 saves the dimension sheet data in two files: the dimension sheet (dimname.xdi) and the compiled file (dimname.dim).
I know that référentiel is used to set up dimensions. Actually, my colleagues in Paris have such a module, called référentiel, to quickly create dimensions. Similar to xdi but then in TM1 Web and a TI process with action button to create / update a chosen dimension. It's more of a template in fact, to update and maintain dimensions.
pikolikoli
- OLAP Product: tm1
- Version: 10.2
Yes True, I work in a french speaking company where they use this term 'Referentiel'. Thanks Wim for the clarifications.Wim Gielis wrote: ↑Wed Jan 20, 2021 11:49 pm I know that référentiel is used to set up dimensions. Actually, my colleagues in Paris have such a module, called référentiel, to quickly create dimensions. Similar to xdi but then in TM1 Web and a TI process with action button to create / update a chosen dimension. It's more of a template in fact, to update and maintain dimensions.
I would like to ask you do you know somewhere where I can read about how this template work and how it is created ?
So I was rightpikolikoli wrote: ↑Fri Jan 22, 2021 12:35 amYes True, I work in a french speaking company where they use this term 'Referentiel'. Thanks Wim for the clarifications.
This template belongs to our colleagues in Paris. It’s their IP. I know it’s an Excel sheet containing several tabs with DBRW formulas and action buttons. The goal is to create and maintain dimensions. I’m afraid I cannot share more details but I know that they will deploy it during their projects at the customer. Hint hint
pikolikoli
- OLAP Product: tm1
- Version: 10.2
Thank you So Much WinWim Gielis wrote: ↑Fri Jan 22, 2021 7:41 amSo I was rightpikolikoli wrote: ↑Fri Jan 22, 2021 12:35 amYes True, I work in a french speaking company where they use this term 'Referentiel'. Thanks Wim for the clarifications.
This template belongs to our colleagues in Paris. It’s their IP. I know it’s an Excel sheet containing several tabs with DBRW formulas and action buttons. The goal is to create and maintain dimensions. I’m afraid I cannot share more details but I know that they will deploy it during their projects at the customer. Hint hint![]()
Thank you Again for your time and your help
Does your company use that template / référentiel ? Or did you only make a general comment about understanding what is going on with the dimensions ?pikolikoli wrote: ↑Fri Jan 22, 2021 8:21 amI"ll Make sure to hunt the moment they will modify the dimensions so I can understand more about it.
