MDX for elements that exist in both subsets
MarenC
Excel Version: Excel 2016
Post by MarenC »
I have 2 mdx based subsets, one to find a variance between the current and next period and another which asks if an employee has an end date.
I now want to combine the 2 to see where the variance is possibly due to an end date.
I can combine the mdx statements into one with an and condition, which is fine, except it makes the mdx string very very long.
So I was wondering if it is possible to write mdx for where the elements exist in both subsets.
Maren
Re: MDX for elements that exist in both subsets
MarenC wrote: Mon Oct 05, 2020 12:28 pm Hi,
Maren
You can reference the name of an existing subset in an MDX query with the [DimName].[SubsetName] syntax so you should be able to do an INTERSECT between the two subsets.
INTERSECT(
    {[DimensionName].[SubsetName1]},
    {[DimensionName].[SubsetName2]})
MarenC
Post by MarenC »
Hi Tomok,
you had one too many parenthesis in that but otherwise worked perfectly, thanks!
Maren
MarenC wrote: Mon Oct 05, 2020 1:01 pm Hi Tomok,
Maren
I accept no responsibility for syntax errors. :)
Actually, why not having less of these, and avoiding syntax headaches ? This works too:
INTERSECT(
    [DimensionName].[SubsetName1],
    [DimensionName].[SubsetName2] )
