Hello!
This is my first post on this forum, so if my description is to complicated, please give me a feedback and i would describe it more precisely.
I have 2 questions connected with tm1 spreading functionality:
1. Do you know is there any way to change default (propotional) spreading method while you type-in value to consolidation?
Unfortunately element weight could not be the answer as I want to eg. load data to some measures and keep them as weight 1.0 but users want to spread data on different measures with the 3 last month avg sales % to Product Group split per each SKU.
I have tested 2 ways:
-dummy measure with the % split and relative propotional spread - works good but you have to right click and choose it every time
-fill the measure on which i want to spread data with the % split, so when i type values on the consolidations the values are propotionally splited but of course it works only once.... After deleting values on some consolidation levels i loose the prepared % split values..
All after all the desirable effect would be that i could some way use relative proportional spread (in relation to the % split) without right clicking (and using spread options), only by type-in consolidation spread multiple times?
2. Is there any way to show alert/messagebox/dialog box/some other visual sign before user type in value on consolidate? Users use only tm1web without data commition mode.
If there is no such option, do you know whether i can disable the type-in consolidation data entry while having the possibility of spreading using right click-> data spread -> (data spread type)? I was playing with the Consolidation TypeIn Spreading=DENY and Allow Spreading=GRANT but it does not work as i wanted...
Spreading customisation
- paulsimon
- Version: PA 2.0.5
Re: Spreading customisation
This probably only answers part of your question, but you can control spreading as follows :
In Architect/Perspectives, Right click on the Server and select Capability Assignments. You can Grant or Deny the right to Consolidation TypeIn Spreading by Group.
I am not sure what else you are trying to do. Have you looked at Holds?
Personally I never use spreading.Occasionally, I find users that understand spreading enough to use it safely but for the rest of the population it is usually better for a developer to use rules or a specific TI process to give them the specific spreading operation that they actually need.
A slight bend on the question: you can write C level formulas to 'fix' all but one of the components (either constants or DBs), then inputting in consolidated cell will adjust only the 'adjustable' component of calculations.Lisciu wrote: ↑Wed Aug 05, 2020 10:35 am Hello!
I.e. you can have a consolidation of Revenue = C: Volume * Price and if you fix either of these with a DB, inputting in Revenue will recalculate the other one.
This allows you to predefine the spreading paths by having a set of consolidated elements.
There be dragons down that road, it gets really tricky fast and it's C level rules, so performance can suffer.
I wrote about this here: https://www.ykud.com/blog/cognos/tm1-in ... reak-back/
