Hello everyone,
Is there an easy way to retrieve the TM1 Web Application (Contributor) name in a cube using the GUID ? }ElementAttributes_}tp_applications cube gives a lot of useful information but unfortunately the name/alias of a TM1 Applications is not one of them.
I looked in almost all control cubes but I found nothing.
Thanks !
Get TM1 Web Application name using the GUID
Re: Get TM1 Web Application name using the GUID
I believe if cube cell comments are entered from the TM1 Application Web application then the GUID of the particular application shows up as an element in the }Annotation_ApplicationID control dimension which is used in the }CellAnnotations cubes.
I don't ever use Application Web so in this dimension so I only ever see the default element "}*" but I'm assuming that if using Application Web then elements would be created corresponding to each Contributor application.
Emixam
Thanks lotsaram, but unfortunately, not all of our apps have cell comments. I literally opened all control cubes and I came to the conclusion that there is no way to retrieve this information in a cube.
IMO, it should be an available information in the }ElementAttributes_}tp_applications cube but who I am to judge
Have a good day !
Have a good day !
