tm1 log file delete
manu0521
OLAP Product: IBM TM1, Planning Analytics
Version: PA 2.0.5
tm1 log file delete
Post by manu0521 »
Hi ,
I have a vb script that deletes the logs which are older than 3 days,
I have 3 instances and the task has 3 steps which deletes the logs from 3 instances .
I am having issue where the task goes to running state and not completes. When looked at it there is some tm1event log which it canot delete.
Any one had similar issue .
Script is below
option explicit
Dim rootFolder, files, File, f1, fso
set fso = createObject("Scripting.FileSystemObject")
'change folder here
set rootFolder = fso.GetFolder("D:\APAC\Logs\")
set files = rootFolder.Files
For each File in files
'On Error Resume Next
Set f1 = fso.GetFile("D:\APAC\Logs\"&File.Name)
'change amount of days here; files where last modification was longer ago than 5 days will be deleted
if File.DateLastModified < (date-3) then
'wscript.echo "deleted"
f1.delete
end if
NEXT
orlando
Version: PAL 2.0.8
Re: tm1 log file delete
Post by orlando »
manu0521 wrote: Tue May 26, 2020 1:14 am
The tm1event.log can only be deleted when the services are finished.
I see this file since i use the "IBM Cognos TM1 Operations Console" - but can also be coincidence, because at that time we also went on a new TM1 version.
If you want to delete the file you have to stop the services - delete - restart.
best regards,
orlando
scrumthing
Version: 11.x
Excel Version: MS365
Post by scrumthing »
Why would you want to delete that particular file? Just don’t do it. It is a nice and short log of shutdowns and startups of your server.
ykud
Post by ykud »
orlando wrote: Tue May 26, 2020 9:05 am
This is a PA 2.0.3 feature https://www.ibm.com/support/knowledgece ... ogger.html
you can disable it by using EventLogging=F in tm1s.cfg (it's on by default), kudos to Andy Key for pointing this out to me a while back.
Y
orlando
Version: PAL 2.0.8
Post by orlando »
ykud wrote: Wed May 27, 2020 11:17 pm
Y
there is no icon, so: thumbs up!
MarenC
Excel Version: Excel 2016
Post by MarenC »
ykud had done very well not to have become an MVP! :D
MarenC wrote: Thu May 28, 2020 8:00 am ykud had done very well not to have become an MVP! :D
15 posts short of getting into the voting cycle as of the time of writing.
