I have all but given up on using drill throughs anymore as the inability to get RETURNVIEWHANDLE to return a customized view has become an albatross. I have a somewhat cumbersome technique that seemed to work in 2.0.5, but have heard that has even gone away in 2.0.8
Is anyone still customizing drill views and getting them to properly render in PA? If so, I'd certainly appreciate the magic incantation.
Drill Through custom views/subsets
- PavoGa
- Excel Version: 2013 PAW
Ty
Cleveland, TN
Cleveland, TN
Re: Drill Through custom views/subsets
Yes I do. I replied to your PM.
- paulsimon
- Version: PA 2.0.5
We are still on 2.0.5 so I would be interested to know if this technique no longer still works in 2.0.8
In the EPILOG put IF( 1 = 0 ) around the generated statements so they don't get executed, then put your custom RETURNVIEWHANDLE below.
IF( 1 = 0 ) ;
RETURNVIEWHANDLE('zTD_Financial','zTD_All');
ENDIF ;
RETURNVIEWHANDLE( vCube, vView ) ;
Hi Paul,
I still do that in a generic process to create drills to level 0 views, that are created on the fly when the drill is executed. It leaves a bunch of views and subsets but a clean up process and good naming conventions can solve this.
Can you be more specific about your issues Ty?
We are using the same method that Paul indicated and not seeing any issues with functionality. (Yes of sure there are some issues that the object names displayed in the UI don't seem to be updated, but the more important thing is that it actually works).
I have exactly the same experience as Lotsaram.lotsaram wrote: ↑Thu Apr 09, 2020 8:01 am Can you be more specific about your issues Ty?
- PowerDim
- Version: PAL 2x
- Excel Version: Excel 2019
Hello everyone!
Our version: PA 2.0.8 (11.6.00000.14)
We use customized views in drills in exactly the same way.
Unfortunately, we observe that when we change the name of a view in the Prolog, nothing happens. Drill opens the view that is selected on the Source tab, but with new correct subsets. At the same time, the view with new name is created and is available in the cube views.
Perhaps, does anyone managed to find a solution to this problem?
Nothing was found in the fix-lists 2.0.9, 2.0.9 IF2 and 2.0.9.1 (https://www.ibm.com/support/pages/node/6192099).
Dmitry
Dmitry
Dmitry
Dmitry
- PavoGa
Bit of a delay in responding, but I'm using them. Not thrilled about the title dimension issue, but simply assigning every dimension to a row/column at least properly displays the custom subsets within the rendered view; the client can then simply rearrange the dimensions as they wish.lotsaram wrote: ↑Thu Apr 09, 2020 8:01 am Can you be more specific about your issues Ty?
Here is a link to another discussion about the topic:
https://www.tm1forum.com/viewtopic.php? ... h&start=20
Ty
Cleveland, TN
Cleveland, TN
- OLAP Product: TM1\Cognos Express
- Version: All
- Excel Version: 2013 + 2016
I know this thread is very old, but I am still having an issue where my drill-throughs do not assign my custom subsets to the view for some Title\Context dimensions. I have attempted two methods with creating a drill-through, the first being where the datasource is set to 'None' and I create an entirely custom view in the prolog (assigning title, row, and column dimensions) and the second method where I pre-canned a view in the target cube with the drill through simply updating the existing subsets. However, in both instances the returned view does returns "(Unnamed)" subsets for 4 out of 5 title dimensions - interestingly the subsets are created they are correctly created in the background they are just not in the output view (including the pre-canned view). I would also point out that the behaviour is inconsistent, I have a drill-through to another cube using the first method described above which is correctly assigning all custom subsets to the title dimension - so I am absolutely stumped as to why drill-throughs don't behave the same on different cubes.
I have raised this with IBM but was basically fobbed off and told custom views in drill-throughs are not supported. Although even the pre-canned view as a datasource doesn't work, so it seems like a bit of a cop out from my perspective
Any thoughts\advice would be greatly appreciated.
