PAW Widget Selector Alias
mnasra
Version: 2.0
Excel Version: EXCEL 2013
Post by mnasra »
This is a very basic question, but I cannot find the answer.
I just added a widget selector to a PAW view. I need to show the Alias and not the principal name.
I cannot find where.. Sorry, I am sure the answer is obvious, but cannot find it.
Micheline
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: PAW Widget Selector Alias
Post by ascheevel »
Click on the widget and then click the little pencil in the upper right corner to bring up the subset editor. Within there, the alias selector is the little person (head & shoulders) in the top middle of the subset editor.
mnasra
Version: 2.0
Post by mnasra »
Thanks. But for some reason the little pencil does only 1 thing: edit the title. Am I missing somethin so obvious I could not see it.
Micheline
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
My mistake, I thought you were referring to an element selector that you can create by dragging the dimension out of an exploration view onto the canvas. I see now what you mean about the selection widget not having access to the set editor. You can use the method I mistakenly thought you were referring to, but you'd need to click on it to see the elements. You could also delete your current selection widget and re-add from a subset that has the desired elements.
mnasra
Version: 2.0
Post by mnasra »
Ah…. That's it. Adding the selector from a subset instead of from the dimension itself.
I knew it had to be something simple.
Thank you. Very appreciated.
Stay Safe
Micheline
