Hi, all
I am testing PAL 2.0.8 and found there are the following two harmless errors in ODBC Driver 17 for SQL Server in the TM1 server log.
But no such error in 10.2.2 for the same process. Any idea? Thanks.
4936 [2] ERROR 2020-01-24 10:37:50.232 TM1.SQLAPI S1000[Microsoft][ODBC Driver 17 for SQL Server]Connection is busy with results for another command
4936 [2] ERROR 2020-01-24 10:37:50.232 TM1.SQLAPI S1010[Microsoft][ODBC Driver Manager] Function sequence error
ODBC errors in PA 2.0.8
- macsir
- Version: PAL 2.0.9
Re: ODBC errors in PA 2.0.8
Forgot to mention, I am on Windows Server 2019.
Hi macsir.
Not sure whether you ever managed to get rid of these errors? I am experiencing the same thing on a model that's on 2.0.8 on the IBM PA Cloud. The errors appear harmless and the process completes successfully, but they are logged in the tm1server.log, which is obviously not ideal. Did you manage to get rid of them / identify what they were aiming to convey?
