Hi there
We have put in a tm1s-log.properties file in order to log user logins. However, after doing this, logging to the tmserver.log file has stopped.
I would like the have logging continue, as well as the user logging configured in the log properties file.
Is this possible? Have I configured the log properties file incorrectly? Please refer below for contents of log properties files.
Many thanks!!!
Chris
# Specify GMT or Local timezone
log4j.appender.S1.TimeZone=local
log4j.logger.TM1.Lock=ERROR
log4j.logger.TM1.Login=DEBUG, LOCK
log4j.additivity.TM1.Login=false
log4j.appender.LOCK=org.apache.log4j.SharedMemoryAppender
log4j.appender.LOCK.File=lock.log
log4j.appender.LOCK.MaxFileSize=100 MB
log4j.appender.LOCK.MaxBackupIndex=20
log4j.appender.LOCK.TimeZone=GMT
						Tm1Server log stops after tm1s-log properties file
- qml
 - Excel Version: 2007 - 2016
Re: Tm1Server log stops after tm1s-log properties file
You need to set up your base S1 logger:
log4j.logger.TM1=INFO, S1
log4j.logger.TM1.Lock=ERROR, S1
log4j.appender.S1=org.apache.log4j.SharedMemoryAppender
log4j.appender.S1.MemorySize=10 MB
log4j.appender.S1.MaxFileSize=100 MB
log4j.appender.S1.MaxBackupIndex=20
log4j.logger.TM1.Login=DEBUG, S2
log4j.appender.S2=org.apache.log4j.SharedMemoryAppender
log4j.appender.S2.File=login.log
log4j.appender.S2.MaxFileSize=100 MB
log4j.appender.S2.MaxBackupIndex=20
log4j.appender.S2.TimeZone=local
Kamil Arendt
				chewza
 - Version: 9.5
 - Excel Version: 7
Hi Kamil
Many thanks. So does the S1 part ensure everything logs to the Tm1Server log (exactly as before), and the S2 part logs log logins to the login file?
Many thx
Chris
Many thx
Chris
- qml
Precisely. The names S1 and S2 given to the logger streams are totally arbitrary, BTW. Other names can be used too.
Kamil Arendt
