Unable to destroy Cell Security cube
jamesbennett
OLAP Product: IBM Cognos TM1
Post by jamesbennett »
I recently created a Cell Security cube via TI using the CellSecurityCubeCreate function. However, now I would like to destroy and recreate the cube as I need to include another dimension that was missed out the first time around. I have tried running another TI with the CellSecurityCubeDestroy function in the prolog - I get the message stating 'Process completed successfully' but the original cell security cube is still there, unchanged.
I note from the documentation of this function that 'The GrantSecurityAccess property must be set for this TurboIntegrator process to succeed.' Could that be preventing me from destroying the cube - how do I confirm the GrantSecurityAccess property? Or is there some other reason why this function might not be working?
Re: Unable to destroy Cell Security cube
Did you right-click the process and set the relevant checkbox for security access ?
jamesbennett
I hadn't - I wasn't aware of such an option - however having just ticked that I've rerun the process and get the same issue, 'Process Completed Successfully' but no impact on the cube.
jamesbennett wrote: ↑Mon Jan 20, 2020 11:20 am I hadn't - I wasn't aware of such an option - however having just ticked that I've rerun the process and get the same issue, 'Process Completed Successfully' but no impact on the cube.
Show us the code please.
jamesbennett
Wim Gielis wrote: ↑Mon Jan 20, 2020 11:22 am Show us the code please.
CellSecurityCubeDestroy('}CellSecurity_Allocations');
As mentioned it's in the Prolog tab of the TI, Data Source set to None.
You haven't followed the documentation by IBM:
https://www.ibm.com/support/knowledgece ... stroy.html
They have an example:
CellSecurityCubeDestroy('DataCube');
Leave out the first part of the name.
jamesbennett
I see - obvious when you point it out. Thanks for your help, that works well now.
