MDX "JOIN"
MDX "JOIN"
Is there a way to do an MDX equivalent of an SQL Join between two dimensions? Right now the way I do it in TI is to do a While loop and cycle through Dim2, building a Dim1 subset of the elements that are in both dimensions or vice versa. Doing it in MDX would mean a lot less code.
Re: MDX "JOIN"
You can try to use the GENERATE command to do this. I do not have the best example to hand but you would do something like:
{GENERATE(
{[Month_A].Members},
{StrToMember("[Month_A].[" + [Month_B].CurrentMember.Name + " ]")}
Basically doing a for each Member in Month (could be another dimension), build a member based on an "attribute" of that member. "Attribute" could be the name, index, a real attribute etc. etc.
In this example, I am using the same dimension but as long as you return a valid member defined by the StrToMember part, you should be fine.
That is the theory I use, YMMV
Good luck.
BR, George.
Re: MDX "JOIN"
Not sure exactly what you mean, but if you mean a cross-join or the product of 2 or more dimensions this is easy with the dimension1 * dimension2 syntax. e.g.
SELECT
      NON EMPTY
         { Tm1FilterByLevel( TM1SubsetAll( [plan_version] ), 0) }
         * { Tm1FilterByLevel( TM1SubsetAll( [plan_business_unit] ), 0) }
      ON ROWS,
PavoGa
Excel Version: 2013 PAW
Re: MDX "JOIN"
Post by PavoGa »
Here is another method that uses GENERATE as gtonkin suggests, but does not require the StrToMember. A subset we use:
GENERATE(
	TM1DRILLDOWNMEMBER( {[Employee].[Non-Active Employees]}, ALL)
	, FILTER(
		TM1SUBSETALL([Employee - Historical])
		, [Employee - Historical].currentmember.name = [Employee].currentmember.name)
Unfortunately, in some versions of PA, if a value is passed to StrToMember that does not exist in the dimension, the instance will crash.
Ty
Cleveland, TN
Re: MDX "JOIN"
I am talking about an INNER JOIN. I have two dimensions, one with all the accounts in the GL and one with only a few accounts. I want an MDX that will create a subset on the all accounts dimension of only the elements that exist in both dimensions. Thanks for the ideas. I'll test them out tomorrow.
Re: MDX "JOIN"
Post by David Usherwood »
Sorry to be late on this, but what about INTERSECT?
https://www.iccube.com/support/document ... ersect.php
PavoGa
Re: MDX "JOIN"
Post by PavoGa »
David Usherwood wrote: Fri Oct 25, 2019 8:59 am Sorry to be late on this, but what about INTERSECT?
Intersect requires the same dimensionality in both sets. Tom is asking for the inner join of two dimensions.
Ty
Cleveland, TN
