What to do so that corrupt view should not get generated?
habibullah.sayyed
Version: v10.x
Excel Version: excel 2016
Post by habibullah.sayyed »
Hello everyone,
Corrupt views are getting generated, the reason may be deleting element from subset or any reason. But I dont want it to get generated, so what do I do so that the corrupt views dont get generated ?
AND
Using MDX, can I prevent from generating corrupt views ?
Re: What to do so that corrupt view should not get generated?
So you would like to avoid corrupt views at any rate ?
Then don’t delete elements, don’t change dimension structures, don’t change anything at all. To avoid working with hardcoded element names, you could consider levels. But in the end it’s just something to live with. Open up the relevant vue and sub files in a text editor to understand why a view has gone corrupt.
habibullah.sayyed
Version: v10.x
Wim Gielis wrote: Sat Oct 19, 2019 9:15 am So you would like to avoid corrupt views at any rate ?
YES...
Wim Gielis wrote: Sat Oct 19, 2019 9:15 amThen don’t delete elements, don’t change dimension structures, don’t change anything at all. To avoid working with hardcoded element names, you could consider levels. But in the end it’s just something to live with. Open up the relevant vue and sub files in a text editor to understand why a view has gone corrupt.
Can you tell more reason for corrupt view.
& is their any TI or setting so that view should not get corrupt?
Did you really read and understand my previous post ?
