After Upgraded TM1 10.2 in Planning Analytics . Action Button is not visible in TM1 WEB.
Any idea?
PA : Action button not visible in TM1Web
habibullah.sayyed
- Version: v10.x
- Excel Version: excel 2016
Re: PA : Action button not visible in TM1Web
Does the name of the button shifting and getting invisible? Cause I also facing this problem...
HighKeys
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
Got the same issue @ PA 2.0.4 now with 2.0.8 its fine.habibullah.sayyed wrote: ↑Fri Sep 20, 2019 11:57 am Does the name of the button shifting and getting invisible? Cause I also facing this problem...
BR
habibullah.sayyed
- Version: v10.x
Is there any solution for this?HighKeys wrote: ↑Fri Sep 20, 2019 12:04 pmGot the same issue @ PA 2.0.4 now with 2.0.8 its fine.habibullah.sayyed wrote: ↑Fri Sep 20, 2019 11:57 am Does the name of the button shifting and getting invisible? Cause I also facing this problem...
BR
HighKeys
Do you use 2.0.4?habibullah.sayyed wrote: ↑Fri Sep 20, 2019 12:24 pmIs there any solution for this?HighKeys wrote: ↑Fri Sep 20, 2019 12:04 pmGot the same issue @ PA 2.0.4 now with 2.0.8 its fine.habibullah.sayyed wrote: ↑Fri Sep 20, 2019 11:57 am Does the name of the button shifting and getting invisible? Cause I also facing this problem...
BR
Updating is not a opinion for you?
