Question about formatting rule calculated cells in TM1
lynnsong986
Post by lynnsong986 »
Hello, I have a measure dimension named "RevenueMeas" where all elements need to be in currency format. I set the format up using "Edit Elements Attributes" as currency. However these cells are rule driven and somehow the cube view doesn't show the numbers in currency format. How can I fix this? thanks!
Re: Question about formatting rule calculated cells in TM1
They should still be formatted as currency.
Did you apply formatting to elements of other dimensions in that cube ?
lynnsong986
Thanks yes I have too many dimensions in that cube and applied formatting all over the place. I just did a clean up and it is good now, thanks again for your fast reply Wim!
The documentation explains it.
To ensure that TM1 applies the format for the cube measures, position the dimension containing the measures as the bottommost column dimension.
  • TM1 first checks the elements in the column dimension for display formats. If dimensions are stacked, TM1 checks from the bottom upward.
  • If no format is found, TM1 checks the elements in the row dimension for display formats. If dimensions are stacked, TM1 checks from right to left.
  • If no format is found, TM1 checks the title elements for display formats. The elements are inspected from right to left.
  • If no format is found, TM1 applies the format for the current view.
