Hi Guys
Not sure if it's just me, but this doesn't seem to be working. I have added 2 views to workspace, and ticked the "Synchronize Sandbox" option for both.
However, when I change the sandbox on one, and other doesn't automatically change.
Any idea why?
Chris
Paw - Synchronise Sandboxes
Re: Paw - Synchronise Sandboxes
If they are on different tabs you need to also set the synchronisation scope to book instead of sheet.
- Version: 9.5
- Excel Version: 7
They are on the same sheet
Done a quick test myself and it seems ok - I must admit that sandboxes are something that haven't often been used in models I have developed/worked on - the functionality seems ok in my set up that I have at the moment though.
What version of PA and PAW are you on?
Also does the synchronisation work for dimensions?
I have seen on occasion that I need to actively F9 inside one of the views for it to pick things up but that's normally more to do with MDX (which I still use a lot in addition to synchronisation) rather than the sync options.
