Slow Login in Architect
- macsir
- Version: PAL 2.0.9
Tm1 10.2.2 fp7
I noticed that for around two weeks, it will sometimes become very slow to login from Architect or Perspectives or Web. The Architect I was testing just sits on the TM1 server itself. Thus there shouldn't be any network issue. After a reboot, the duration of login went back to normal (less than 10 seconds). I am aware that the login duration is pretty much depend on the number of TM1 objects residing in the server.
However, after a period of time (days or weeks), it goes up to around 20 seconds, or 40 seconds or even 60 seconds randomly.
I checked the logs in every place and seems to be normal. No special findings. The only thing I can tell is when it happened, the server has many (~90-100) sessions concurrently although most of them are idle.
Could anyone share any idea on it? Thanks.
- Version: All
- Excel Version: All
Re: Slow Login in Architect
Which IntegratedSecurityMode are you using and are you using single sign on etc..?
- gtonkin
Is there a difference when you use the server name vs the IP address? Have had numerous issues when the DNS is fritzed - it takes forever to connect the dots.
- macsir
Cam security mode 5 with sso. The cognos is installed on same server where TM1 is. Thanks.Edward Stuart wrote: ↑Fri Jun 07, 2019 1:31 pm Which IntegratedSecurityMode are you using and are you using single sign on etc..?
- macsir
I tried using IP in architect. No difference and still slow. Thanks
- Version: All
Once you are logged in are there further issues or is it only login that sees the delays?
Do you have access to Cognos BI Security to see if anything odd is occuring at that end? My guess would be that the 'normal' identifiers for TM1 are clear so it could be a BI related issue?
- macsir
Thanks, no further slowness issue after logged in as I observed.Edward Stuart wrote: ↑Mon Jun 10, 2019 12:11 pm Once you are logged in are there further issues or is it only login that sees the delays?
I checked BI side and no special finding. What I can see from TM1 top is, after double clicking the server, it took around 5 seconds for showing "??? - SystemServerConnectWithCAM" and then after around 4 seconds, my logging name is shown correctly. After that, TM1 server took 1 or 2 seconds to show all objects. Therefore, the total duration is around 10 seconds now after a fresh reboot several days ago. Is it quite normal if someone can test it as well? Thanks. I don't think it is slow. When the issue really happened last time, the server took ages to show all objects after authenticating my user name with CAM.
- macsir
By the way, TM1 web was also slow when I had the issue. Now it takes around 15 seconds to show applications and views after open the URL in Chrome.
- gtonkin
Anything suspicious in your tm1admsrv log files?
May be worthwhile adding some additional loggers in your tm1s-log.properties to see if there is anything untoward going on e.g.
Have a look here for more loggers.
log4j.logger.TM1.Server.Network=DEBUG, STATS
log4j.appender.STATS=org.apache.log4j.SharedMemoryAppender
log4j.appender.STATS.MemorySize=5 MB
log4j.appender.STATS.File=tm1STATS.log
log4j.appender.STATS.MaxFileSize=5 MB
log4j.appender.STATS.MaxBackupIndex=5
log4j.appender.STATS.Timezone=Local
- macsir
Thanks, that's a good point. I will take action on them and report back.gtonkin wrote: ↑Tue Jun 11, 2019 11:34 am Anything suspicious in your tm1admsrv log files?
May be worthwhile adding some additional loggers in your tm1s-log.properties to see if there is anything untoward going on e.g.Have a look here for more loggers.Code: Select all
log4j.logger.TM1.Server.Network=DEBUG, STATS log4j.appender.STATS=org.apache.log4j.SharedMemoryAppender log4j.appender.STATS.MemorySize=5 MB log4j.appender.STATS.File=tm1STATS.log log4j.appender.STATS.MaxFileSize=5 MB log4j.appender.STATS.MaxBackupIndex=5 log4j.appender.STATS.Timezone=Local
- macsir
Just want to share,
The login duration was slowed down to around 20 seconds and I checked the DEBUG server log. There is no ERROR or WARNING at all.
Compared to a login from fresh reboot, the log is showing more
Not sure what that mean but seems those timeout events were consuming considerable time. Maybe I am wrong as it is out of my technical scope. But for now, the most practical workaround would be rebooting server weekly rather than monthly.
105416 [] DEBUG 2019-06-19 05:59:55.385 TM1.Event mt_WaitForMultipleObjects: Timed out.
85292 [] DEBUG 2019-06-19 05:59:55.385 TM1.Event mt_WaitForMultipleObjects: Timed out.
28796 [] DEBUG 2019-06-19 05:59:55.385 TM1.Event mt_WaitForSingleObject: Timed out on event 0x0000000000000144.
33076 [] DEBUG 2019-06-19 05:59:55.385 TM1.Event mt_WaitForMultipleObjects: Timed out.
28796 [] DEBUG 2019-06-19 05:59:55.385 TM1.Event mt_WaitForSingleObject: Waiting for event 0x0000000000000144.
71340 [] DEBUG 2019-06-19 05:59:55.385 TM1.Event mt_WaitForMultipleObjects: Timed out.
28796 [] DEBUG 2019-06-19 05:59:55.400 TM1.Event mt_WaitForSingleObject: Timed out on event 0x0000000000000144.
28796 [] DEBUG 2019-06-19 05:59:55.400 TM1.Event mt_WaitForSingleObject: Waiting for event 0x0000000000000144.
28796 [] DEBUG 2019-06-19 05:59:55.416 TM1.Event mt_WaitForSingleObject: Timed out on event 0x0000000000000144.
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
When you log in to TM1 with ISM=5, TM1 checks CAM client*group mapping (and adds new client if any). This can be reason
How many groups do you have in TM1?
How many groups does the "slow" user belong to?
Do you have any rules in }Clientgroups cube? Any feeders from it?
Does the problem affect all users?
- macsir
1. Around 70 groups but not all of them have membersElessar wrote: ↑Wed Jun 19, 2019 6:33 am Hi,
2. when it slows, all groups I tested are slow
3. No
4. all users I know including myself, admin.
Thanks.
- Elessar
- Version: 2.0.9
There should be "CAM_LPSvr.exe" processes. Do they consume CPU during slow user connections?
It can consume the whole core (for example, 25% in 4-core processor). If so, try to kill it in Task manager. Cognos will recreate new, if it needs.
And the most obvious (sorry if I didn't find this above ): did you try to restart Cognos service?
- macsir
I did search "CAM_LPSvr.exe" and nothing special on the consumption.Elessar wrote: ↑Thu Jun 20, 2019 6:38 am There should be "CAM_LPSvr.exe" processes. Do they consume CPU during slow user connections?
I will try to restart Cognos service next time to see if it was improving.
- Excel Version: 2013
Do you use SSL? If so, between which components?
Is BI and TM1 installed on the same server? Is TM1 installed on one or multiple servers?
Do you have any anti-virus on the servers?
Would it be possible for you to test with native login once to see if you still if its still slow?
- macsir
1.Yes, UseSSL=T but CAM is not using SSL, means it is HTTP rather than HTTPSBakkone wrote: ↑Mon Jun 24, 2019 5:31 pm Do you use SSL? If so, between which components?
2.Yes
3.Yes but seems not to be relevant
4.Good point, I will try next time.
Thanks.
1, Are you using custom certificates?
2a, Are you using IIS as a webserver for your CAM-installation?
2b, Is the database server for the BI-installation on the same machine?
3, AV can be the death of everything. Would it be possible to turn it off when things are slow to see if things are faster?
Whats the server OS?
What version of Cognos BI?
What Database are you using for your content store?
- macsir
Yes, tm1ca_v2.pem
Yes
DB Server is another server
Has tried disabled but no improvement
Windows 2012
10.2.2
SQL Server
Yes, tm1ca_v2.pem
Yes
Windows 2012
10.2.2
SQL Server
- macsir
Just want to update, looks like the login duration is stable and fast after cleaning lots of obsolete Performance Modeler additions out. Can't say it is 100% the reason but the login period is indeed improved. The cleaning is still in progress.
