Here is an issue. I created a new PAW server to replace an old one. The configuration is the same, and it accesses the same TM1 admin and web server. However, all databases that I still see on old server are not available on the new one. I can successfully login and create a new book, but then the database list is empty, and I don't get any errors.
All your ideas are greatly appreciated.
PAW is unable to access TM1 databases
AskAndAnswer
- Version: 2.0...
dr.nybble
- Excel Version: Excel 2007
Re: PAW is unable to access TM1 databases
Look in the 'prism-platform' messages.log file to see if any errors are occurring when fetching the list of TM1 Servers from the admin host URL.
AskAndAnswer
- Version: 2.0...
Where are they located on Linux server?
AskAndAnswer
- Version: 2.0...
I found messages.log file on the server, the only issue I see is Java security certificate is not trusted. I guess I need to finish SSL install before I can test the server.
dr.nybble
If you have a custom SSL certificate you will need to follow these instructions:
https://www.ibm.com/support/knowledgece ... rvers.html
