PAW Docker Containers not starting up
dharav9
Version: 10.3
Post by dharav9 »
Hi, All
Environment: Windows Server 2016
PAW 2.0.37
DOCKER 18.09.3
I do not see any containers (docker ps & docker ps -a).
I did execute (./scripts/paw.ps1) command and it throws following error.
PS D:\paw> ./scripts/paw
Adding custom certificate authority certificates to the system.
Unable to find image 'pa-docker:6000/planninganalytics/ibm-java8:latest-windowsservercore' locally
C:\Program Files\docker\docker.exe: Error response from daemon: Get https://pa-docker:6000/v2/: dial tcp: lookup pa-docker: no such host.
See 'C:\Program Files\docker\docker.exe run --help'.
Adding certificate authority certificate 'applixca.pem' to cacerts
Execution failed with exit code 1
At D:\paw\scripts\init.ps1:58 char:13
+ throw "Execution failed with exit code $LASTEXITCODE"
+ CategoryInfo : OperationStopped: (Execution failed with exit code 1:String) [], RuntimeException
+ FullyQualifiedErrorId : Execution failed with exit code 1
I found that Hyper-v Virtual Switch Extension Adapter could not start. See the following image:
Thank You
Dharav
Switch.docx
(82.69 KiB) Downloaded 298 times
dr.nybble
Excel Version: Excel 2007
Re: PAW Docker Containers not starting up
Post by dr.nybble »
Run the Start.ps1 script -- looks like the images are not loaded.
dharav9
Version: 10.3
Post by dharav9 »
Hello, dr.nybble
It seems images are not loading because Ethernet network is disable. I see the Virutal switches are not working and due to which we cannot enable Ethernet.
I performed ./start.ps1 and it throws parameter is incorrect error.
Installing/Updating IBM Planning Analytics Docker images
Loading image file D:\paw\images\images.tar, this may take a while...
Something went wrong at step 'Installing/Updating IBM Planning Analytics Docker images'
re-exec error: exit status 1: output: ProcessBaseLayer \\?\C:\ProgramData\docker\windowsfilter\c8b41fca42a2fd7b804a3cf54
ef2e26a28cee52ab1a0f05ffe16fc7caba2763e: The parameter is incorrect
Please Advise.
Thank You
Dharav
