Access issue for specific active forms
spartan
OLAP Product: IBM cognos
Post by spartan »
Hello All,
I have scenario like, a user who has write access on the active sheets cannot able to make changes in those sheets(although he has write acess for the cubes from where the report is generated), even he cannot type anything from tm1 web, the cell is not editable in tm1 web.
As i can edit the values from my side as i am an admin.
Can anyone help me out in this case.
Re: Access issue for specific active forms
Are you sure that the sheet is at the N / lowest level?
spartan
Post by spartan »
Hello Steve,
Yes, this sheet is at lowest level and the user made changes earlier as well, since couple of days he is afcing this issue.
He has write access aswell.
You'll need to do more analysis, it sounds like the user doesn't have the level of security that they think they do. Suggest the users navigates to the relevant location in the cube viewer to see what they really have.
Right click on the cell and select edit status, this should say what is blocking.
