Sort cubes alphabetically in PAW after applying cube aliases
CRP0021
Version: 10.3
Post by CRP0021 »
Hello all,
Was looking for some advice if there is some sort of config setting which would allow me to sort my cubes alphabetically in TM1 Web & PAW after applying a caption attribute?
Here are the details:
The image below are the original cube names:
Original Cube Names.png (46.61 KiB) Viewed 2937 times
This image are the cube caption names I have attached:
New Cube Names.png (35.74 KiB) Viewed 2937 times
This is the }CubeAttributes cube:
Cube Attributes.png (46.1 KiB) Viewed 2937 times
So working as expected but would like to know if I can sort the list of cubes alphabetically somehow?
Any advice would be much appreciated.
Thanks All!
jim wood
Version: PA 2.0.7
Re: Sort cubes alphabetically in PAW after applying cube aliases
Post by jim wood »
Moved to the correct forum.
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble »
Suggest you contact support to log a defect, or create a RFE.
