FileExists function returns 1 even when file is not present
amit_hhh
Version: 10.2.2, 11
Excel Version: Excel2010
Post by amit_hhh »
I am facing a strange issue in TI where FileExists function returns 1 even when the file is not present in the specified directory. It returns 1 also when the file is present.
Not sure why it is happening and it is causing TI logic to fail. Please suggest.
Thanks!
Amit Saxena
India
bgregs
Version: 2.0
Re: FileExists function returns 1 even when file is not present
Post by bgregs »
Hi!
Would you be able to post the code that is encountering the error? If you have a variable that is holding the file path, could you also post the declaration of that as well? The more the better! :D
amit_hhh wrote: Tue Jan 08, 2019 5:38 pm Hi,
Thanks!
This sounds suspiciously like the code is not doing what you think it is doing. In these cases 99% of the time the code is doing exactly what it has been programmed to do, just the programmer made a mistake. We have all been there. Best to 1/ proof read the code (again) and 2/ follow bgregs suggestion. It you don't post the actual code no one can help.
